hardwired a dashcam?
Old Nov 16, 2020 | 08:31 PM
  #46
Samurai00's Avatar
Samurai00
Originally Posted by tike71
Parking mode needs a constant power source to function properly; some mirror taps are constant on and some aren't. But in order for it to not completely drain your car battery you need to utilize a voltage cutoff device. Also most dashcams run on 5v so you'd need a 12v adapter as well.
I'm looking to install a Blackvue DR900X which has built in battery voltage cutoff. I'm trying to figure the cleanest way to install it. As mentioned in this thread fuse tapping would result in the fuse cover not fitting anymore which isn't the end of the world but also doesn't sit right with me lol.
Old Nov 17, 2020 | 09:06 AM
  #47
tike71's Avatar
tike71
The DR900X uses a 12v-24v so you'd be able to tap directly into the car's electrical system. I checked the mirror on my wife's es250 and there is both a constant and switched 12v source in the plug. You're gonna need a multi-meter to figure out which wires they are though. GL with the install, perhaps you can document the whole process?
Thegamemhb
Sep 11, 2019 02:33 AM
mcnelson
Aug 5, 2002 05:13 AM
