Disable rear traffic auto braking
Old Mar 14, 2020 | 02:11 PM
Es1480's Avatar
Es1480
Default Disable rear traffic auto braking
Hi guys, I found out the rear traffic auto braking is a bit too sensitive.
is there a way to disable it or to reduce the sensitivity?
thanks
Old Mar 14, 2020 | 03:02 PM
grp52's Avatar
grp52
See the "Enabling/Disabling the Parking Support Brake" section of the Owners Manual.
Be aware that turning it off turns off more than just rear auto traffic detection and braking. From the manual:
"All of the Parking Support Brake functions (static objects, rear crossing vehicles, and rear pedestrians) are enabled/disabled simultaneously."
Old Mar 14, 2020 | 03:22 PM
LeeSoFL's Avatar
LeeSoFL
Find a less sensitive setting. The feature is very useful. It stopped me from backing into a ladder, laying in the driveway.
Old Mar 15, 2020 | 04:44 PM
bc6152's Avatar
bc6152
And an idiot that walked behind my moving car while I was backing out at a Home Depot... This feature saved my a$$...
Old Mar 15, 2020 | 06:36 PM
PeterA's Avatar
PeterA
I'm not a lawyer but I am wondering if you rIsk additional liability in an accident because you disabled a safety feature on your car, especially if it happened while you were backing up.
Old Mar 15, 2020 | 09:32 PM
carsareus's Avatar
carsareus
How would anyone even know? How would they even know you had that option?
Old Mar 16, 2020 | 06:54 AM
PeterA's Avatar
PeterA
When they depose you, they are going to ask a lot of questions about what happened. The insurance company may even examine the car depending on how serious things are.
Old Mar 16, 2020 | 12:37 PM
grp52's Avatar
grp52
Your 7th Gen ES car will squeal on you.
It is no secret and lawyers definitely know about it, cars now-a-days have Event Data Recorders. God forbid anyone reading the Owner's Manual, but it's all disclosed in gory detail right up front in the "For your information" section under the "Vehicle data recording" and "Event data recorder" headings. As a data types recorded bullet point under "Vehicle data recording" you'll find:
"Operation status of the driving assist systems, such as the ABS and pre-collision system"
Old Mar 16, 2020 | 01:46 PM
mcomer's Avatar
mcomer
grp52 is correct, you can turn off 1) the Auto Braking (front/rear/cross) and still have the Park Assist
chimes active or 2) you can turn off the Park Assist and defeat everything. Older Lexi had the ability
to change the Park Assist range front, rear or both between two distances. That setting is gone but
now we have the much more often used "Mute" to silence the chimes when triggered by drive though
flags and banners. Not the original posters question but you can now change the distance range of
the Blind Spot Monitor between four (4) distances and also change the brightness of the mirror mounted
icons. Solid yellow when car is flanking you, fast flashing yellow icon if you put on that side turn signal.
Old Mar 16, 2020 | 05:17 PM
carsareus's Avatar
carsareus
I'm not an attorney (Are you Peter?) and I leave ALL of my safety devices always on but it wouldn't be very difficult to turn the safety devices back on after the accident unless the car lost all power and functionality. The situation you describe is possible but highly unlikely!
Old Mar 16, 2020 | 07:10 PM
PeterA's Avatar
PeterA
i'm not an attorney either. The car computer logs events, e.g. during a collision. They will disclose the data to police or court order. It records everything that's going on with the car in the event of a collision. Read pages 6 to 9 of your owner's manual.
Old Mar 17, 2020 | 08:51 AM
tnw2933's Avatar
tnw2933
"you can now change the distance range of the Blind Spot Monitor between four (4) distances and also change the brightness of the mirror mounted
icons. Solid yellow when car is flanking you, fast flashing yellow icon if you put on that side turn signal.[/QUOTE]
Does this apply to the 2019 Luxury ES350? If so, how does one change the distance range of the BSM and change the brightness of the mirror mounted icons?
Thanks in advance for responding.
Tom
Old Mar 17, 2020 | 09:47 AM
mcomer's Avatar
mcomer
Press left steering wheel spoke "Menu" button (three overlapping pages w/return arrow)
Four arrow square rocker left or right until "Settings" icon appears lit up (sprocket or gear icon similar to your phone's settings icon)
Down through settings until you find "Vehicle Settings" Press Four Square center "OK"
Down to "BSM" and press OK. Now you can toggle through range and brightness. Nothing to it, right?
Note: BSM triggers when your speed is above 15 MPH. Do not think it is broken when it does not signal an adjacent car at a stop light.
Old Mar 17, 2020 | 09:56 AM
grp52's Avatar
grp52
[/QUOTE]
Assuming you got the option package that include BSM, the best instructions I've found is a How-To video on Lexus Drivers web site. The 3:24 minute long video HOW-TO USE THE MULTI-INFORMATION DISPLAY SETTINGS IN THE 2019 ES demonstrates going through all the settings with a text side bar in the video that briefly states the options for the setting.
Old Mar 17, 2020 | 04:16 PM
tnw2933's Avatar
tnw2933
Thanks to those who responded on how to adjust settings for BSM and the brightness of the warning in the outside mirrors.s. I checked this out today, and found that both my range and brightness were already set as desired. I appreciate those who posted clear instructions for how to check and adjust these settings.
tex2670
Mar 1, 2020 12:19 PM
tamermido1
GS F (2016-present)
Oct 12, 2016 09:17 PM
TrendyTodd
Automotive Care & Detailing
Jan 7, 2010 11:12 AM
PhilipMSPT
May 28, 2009 01:52 PM
