Rear Camera Detection Unavailable Error
Old Dec 16, 2021 | 10:55 AM
  #31
THOR9's Avatar
THOR9
The next time it happens, leave the vehicle in reverse and turn the steering wheel from lock to lock. This is usually a condition where the the steering axis needs to be reset. As you turn the steering wheel side to side you should see the warning go away.
Old Dec 16, 2021 | 04:29 PM
  #32
babaijebu's Avatar
babaijebu
Originally Posted by babaijebu
Did anyone find a solution to this issue? Mae sure to clean all the sensors but no bueno. Rear camera works fine by the way.
Forgot to update this. Mine fixed itself... not sure what i did, but it lasted 2 days and all went back to normal.
Old Dec 17, 2021 | 07:50 PM
  #33
LexFinally's Avatar
LexFinally
Originally Posted by Toneee
you don’t have to go to the dealer to do this but is recommended so you don’t mess anything up..
Make sure doors are shut
hold the menu button by pressing center pad and turn headlights on and off 3-4 times to activate a setting menu that will pop up on your display.
go to steering angle adjustment and go to max steering angle adjustment, turn the wheel all the way to the left and then press and hold the pad down until it beeps, turn the wheel all the way to the right then press and hold pad until it beeps.
then select steering wheel center and put the steering wheel center and hold the pad until it beeps.
and boom it’s fixed. It will not calibrate if doors are not shut. I just preformed this at the dealer. 2020 es350
Sorry for the dumb question, but... when you say "the pad," do you mean the touchpad?
irishbrahm
ES - 7th Gen (2019-2025)
Dec 21, 2018 12:24 PM
215GS
Oct 17, 2012 07:54 AM
Lohus
Oct 27, 2009 09:01 AM
key51697
Sep 18, 2007 11:03 PM
Lex21
Aug 23, 2007 07:34 PM
