How to change clock
Old Mar 10, 2019 | 01:49 PM
teacher61's Avatar
teacher61
Default How to change clock
I read in my manual that the clocks in car are supposed to change automatically for daylight savings. Mine did not. How do you change it?
Old Mar 10, 2019 | 02:13 PM
bc6152's Avatar
bc6152
This information is in your 2019 owner's manual. You go into Menu, settings, clock, select daylight savings time "on"... Your dash clock will set itself to the current (DST) time...
Old Mar 10, 2019 | 03:12 PM
mikemu30's Avatar
mikemu30
Watch the analog clock as you change the setting. It's cool to see it move😁
Old Mar 10, 2019 | 06:14 PM
pgiinc's Avatar
pgiinc
go to settings
general
clock
enables gps to set time
it will keep time set on both clocks perfectly
Old Mar 10, 2019 | 06:31 PM
MSterling's Avatar
MSterling
Oddly, of all the fancy stuff in the car, that was cool.
Old Mar 11, 2019 | 04:45 AM
LeeSoFL's Avatar
LeeSoFL
Originally Posted by pgiinc
go to settings
general
clock
I got my F Sport the Monday after we went to Starndard Time, so this was my first set. In clock settings, GPS was "on." Does the analog clock adjust without having to go into settings or do you still need to click DST on/off?
Old Mar 11, 2019 | 04:56 AM
ES63's Avatar
ES63
Keep in mind the auto setting for gps is to keep correct time up to the minute as well as geographical time zones I believe. DST on and off must still be changed manually.
Old Mar 11, 2019 | 05:01 AM
pgiinc's Avatar
pgiinc
put dst on and it will change back and forward by itself
you never have ti set it again
Old Mar 11, 2019 | 06:16 AM
mikemu30's Avatar
mikemu30
The little things that excite us
Old Mar 11, 2019 | 06:17 AM
mikemu30's Avatar
mikemu30
Don't you still have to change it when we go off DST??
Old Mar 11, 2019 | 03:30 PM
nsaldanh's Avatar
nsaldanh
Yes you do. When you turn it "On" you are telling it to move to daylight savings time and when you turn it off it turns it off. GPS sources only provide the precise time.
Old Mar 11, 2019 | 04:08 PM
pgiinc's Avatar
pgiinc
leave it on and see what happens in the fall
Philip
2019 ES300h UL eminent white pearl/chateau
2019 NX300h L
eminent white pearl/crème
gone away
2016 ES300h UL eminent white pearl/parchment
2015 NX300h L atomic silver/black
Old Mar 11, 2019 | 05:47 PM
mikemu30's Avatar
mikemu30
Philip
2019 NX300h L
gone away
Ive tried with our RX.* You still have to change it twice a year.
Old Mar 11, 2019 | 05:53 PM
pgiinc's Avatar
pgiinc
is yours a 2019? or a ES? this is a Es forum
they have changed and made them better
Philip
2019 NX300h L
gone away
Old Mar 11, 2019 | 05:54 PM
mikemu30's Avatar
mikemu30
Philip
2019 NX300h L
gone away
My ES is a 2019 so thanks for reminding me which forum this is.
