Plastic engine parts .........
Old Apr 10, 2026 | 01:10 PM
zul8tr's Avatar
zul8tr
Default Plastic engine parts .........
Any problems with cooling system and other critical plastic parts on 2gr fks, None for me just inquiring
Thanks
Last edited by zul8tr; Apr 11, 2026 at 03:29 AM. Reason: corrected the engine code to 2gr fks
Old Apr 10, 2026 | 04:32 PM
landonm86's Avatar
landonm86
The 2GR-FXE wasn’t ever used in the ES350. Did you mean the 2GR-FKS? That was though.
Old Apr 11, 2026 | 03:30 AM
zul8tr's Avatar
zul8tr
Yes a typo I corrected,
Thanks for the catch
Old Apr 11, 2026 | 06:25 AM
ATL350's Avatar
ATL350
Plastic parts are a way of life now in the auto industry. I don’t know that Lexus is really any better or worse that other brands in this regard.
Old Apr 11, 2026 | 10:00 AM
zul8tr's Avatar
zul8tr
What breakage issues due to heat cycling and age have there been with the older 7th gen ES350's and other Lexus and Toyota models using the 2GR FKS that have accumulated miles over the years?
If you know
Thanks
Old Apr 13, 2026 | 07:10 AM
Demanufacture's Avatar
Demanufacture
I had an issue with the PCV intake on the intake elbow this weekend. Unlatched the airbox cover to change my air filter for the 30K service and it snapped clear off. Had to use a screw to remove it from the 1/4 hose, and needle nose to remove the it from the intake elbow. It's only 2 years old but I guess the heat was enough to make the plastic extremely brittle.
https://parts.belllexusnorthscottsda...78780P060.html
Part was only $4 at my local Toyota dealer, but I'll be looking to replace it with a brass part just to avoid this in the future.
Old Apr 13, 2026 | 08:33 AM
Tootsall's Avatar
Tootsall
Aside from the obvious risk of heat causing a polymer degradation and cracking, there is the issue of differing coefficient of thermal expansion between metals and plastics. This will make maintaining a good seal difficult…especially with the current tendency to use cheap, “gasket in a tube”.
rwswalker
Oct 26, 2016 04:19 PM
Brokenis
Apr 17, 2015 09:16 PM
