Annoying Beeps?
My 2025 ES350 UL has started to beep randomly. Started yesterday, single beep every 5 minutes or so. I thought it was a dirty sensor but washed the car today and is still doing it. There is an error message about the TPS . Would this cause this? Or maybe a faulty sensor? Thank you.
Also, immediately after starting your ES, what is the behavior of the tire pressure warning light?
If it blinks for approximately 1 minute and then comes on (with no blinking), that indicates there may be a malfunction in the tire pressure warning system.
See page 351 of the 2025 LEXUS ES250, ES350 OWNER'S MANUAL USA AND CANADA ONLY for the tire pressure warning light symbol with a brief description and from page 354:
If none of the tires are punctured:
Turn the engine switch off then turn it to IGNITION ON mode. Check if the tire pressure warning light comes on or blinks.
▶︎ If the tire pressure warning light blinks for approximately 1 minute then stays on
There may be a malfunction in the tire pressure warning system. Have the vehicle inspected by your Lexus dealer immediately.
Thank you. Turns out it was the overspeed alert.
Also I am taking it in Wednesday for the recall on the rear view camera. I will get them to check it over as it is also making the creaking sound on the pano roof
If you aren't already aware of it, there is a Multi Information Display (MID) setting that controls whether or not the buzzer sound sounds for excess speed of Road Sign Assist (RSA) detected posted speed limits. Other than a terse entry in the 2025 LEXUS ES250, ES350 OWNER'S MANUAL's "8-2. Customization" subchapter's RSA (Road Sign Assist) table on page 410, the owner's manual doesn't have any really detailed instructions for finding and making a change to that setting.
However, Northside Lexus's Melissa O'Connell's "2023 - 2025 Lexus ES Full Tutorial - Deep Dive" video does show where to find and change the MID setting for the RSA "Excess Speed" notification starting at the 53:56 time mark:
P.S. If you expand that video's description section, you'll find Melissa has included a pretty detailed time mark index so you can easily find and jump to a video section covering a specific topic you are interested in.
