Replace Coolant
Mine is a Mastercool I bought from Amazon about 10 years ago. On some cars they really make a difference. The Car Care Nut on youtube did a video on bleeding the coolant system in an ES350 that is really helpful without using vacuum. I like using the vacuum though because it will quickly show a leak if a clamp or something isnt tightened without spilling coolant all over the floor. The main thing I always look for is good heat after filling the coolant system. The heater core usually sits the highest in a vehicle and if there is no heat, than the heater core doesnt have coolant flowing through in it.
Jsst Checked...I have the Mightyvac MV4535
https://www.youtube.com/watch?v=UJe1dbFVoqw&t=346s
https://www.amazon.com/Mityvac-MV453...dp/B000YOMXHA/
For reference, the lexusguide.net Lexus ES (XZ10) Service Manual's Maintenance - 2gr-fks Coolant web page has the coolant replacement procedures for the ES350's 2GR-FKS engine. Something that may not be obvious to DIYers is that there's a cylinder block drain **** plug that needs to be loosened before draining the ES350's coolant.
In that video, the Car Care Nut explicitly states the procedure he's demonstrating does NOT apply to the 2GR-FKS engine used in the ES350 because, as he states starting at the 1:42 time mark, Toyota removed the bleeder from that engine model.
Toyota Cooling System Bleeding for V6 2GR-FE 3.5L THE RIGHT WAY
Ok, the block drain is easy to see and access from underneath. You need 5/16” ID tubing for the radiator drain to prevent a big mess. The drain is horizontal.
Moderator, please change thread title to “Replace Coolant on 2GR-FKS V6”
Just used my Lisle funnel because vacuum kit came with different style air quick disconnect. Drained about 6 qts total from radiator and block. No problem burping system. Added coolant slowly and squeezed upper hose a few times. Temp gage never went above normal.
I replaced coolant on my 99 Avalon 9-10 times and never had an issue. This 2GR-FKS is just as easy. In my opinion, vacuum kit more trouble than it is worth.
Marc780
Sep 18, 2024 06:34 PM
LSDriver94
Aug 1, 2020 11:02 AM
