2024 ESh Easy Access
Old Apr 28, 2025 | 06:28 PM
RocketMan295's Avatar
RocketMan295
Default 2024 ESh Easy Access
Friends, I’m hoping someone can set me straight on the correct sequence to activate my Easy Access/ Easy Exit. Mine seems to be intermittent, but it’s more likely me. Is the sequence engine off - belt off - door open? My driver’s seat rarely backs up.
With a new left knee, this feature is especially helpful. Has anyone perfected the operation of it?
Old Apr 28, 2025 | 06:34 PM
Lexuspicious's Avatar
Lexuspicious
It goes into the driving position when you either: buckle your seatbelt or start the car.
It goes back to the exit position when you either: unbuckle your seatbelt (with the car OFF) or stop the car.
Old Apr 29, 2025 | 04:04 AM
es250fsport's Avatar
es250fsport
I turned that off for seat. I only have that on for steering wheel. I dont like the seat to keep moving backward and forward. Mechanism will wear out faster and it isn't cheap to fix!
Old Apr 29, 2025 | 05:31 AM
RocketMan295
I agree about unnecessary mechanical wear and tear being costly. But I’m more concerned about the wear and tear on my new left knee!
Old Apr 29, 2025 | 07:46 AM
FastDawg's Avatar
FastDawg
Hope this helps.
https://www.lexguide.net/driving_pos...memory-31.html
Old Apr 29, 2025 | 08:59 AM
ndunn's Avatar
ndunn
My hip gives me pain once in awhile and the easy access feature lets me ease in and out without pain. I would much rather replace the seat mechanism than my hip. Without this feature I would be making these adjustments each and every entry/exit.
OTOH, the rear shade going up and down every time I put it in reverse was pretty much a distraction and unwanted wear so I had the dealership adjust the setting so it stays up. I appreciate how this car can be personalized like that.
Old Apr 29, 2025 | 05:55 PM
Lexuspicious
By the way you don't need a dealer to do that, you can do it yourself in the menus of the car
[edit] Seems I am wrong, I can't find it anymore. I must have done it through the OBD.
Old Apr 30, 2025 | 06:59 AM
es250fsport
I am really sorry to hear that. Hope your knee is OK!
Guide on how to do it has already been posted.
I think the vehicle should be stationary as well in order to get into that particular setting. So don't attempt to set it while driving.
Old Apr 30, 2025 | 09:57 AM
mikemu30's Avatar
mikemu30
It will probably be less costly to replace the knee again than the seat mechanism
Old Apr 30, 2025 | 12:03 PM
ndunn's Avatar
ndunn
Nothing in the manual and can't find it in settings so I called the dealership and am waiting on a call back. I may want to turn this option back on at some point if I'm able. Thank you for your help.
Edit: to save others' time here is a link which indicates the auto down rear sunshade feature is programmable by dealer.
https://www.lexus.com/content/dam/le...ES_LPS_CST.pdf
Old Apr 30, 2025 | 06:23 PM
FastDawg's Avatar
FastDawg
I’ve had my left knee replaced. Trust me - you would much rather replace the seat mechanism.
Old May 1, 2025 | 07:48 AM
Lexuspicious
You are right, I can't find it anymore.
Maybe it's something I did through the OBD with an APP.
Old May 2, 2025 | 01:42 AM
RocketMan295
Eureka! Your excellent responses led me to the simple solution: I had memory position #1 (and key fob) set up for my 6’ frame - the linear position was too close to the rearmost end limit. Reset it forward by a quarter inch and - bingo - works every time now.
Not an appreciable difference in exiting/entering ergonomics, just a fun (cool) option to passively utilize. Thanks, everyone for your gracious advice!
Old May 2, 2025 | 05:55 AM
Stanlexusguy's Avatar
Stanlexusguy
OMG, they wouldn't build the seats to go back and forth if there was going to be a long term issue. My son is a certified lexus mechanic. USE THE CAR LIKE YOU ARE GONNA KEEP IT FOREVER. 99.5% you will have no issues.
I had a MB for 7 years. I hated the ENGINE AUTO Stop at a red light. I asked my son, won't that have more wear and tear on the engine? NOPE. Car is build for that kind of abuse . WILL NOT MAKE THE CAR FAIL IN A SHORTER PERIOD OF TIME
Old May 2, 2025 | 05:59 AM
es250fsport
It is simple physics. It will wear out the bearings faster.
