Dashboard Lights Going Crazy
Old Apr 15, 2024 | 03:15 PM
jerseycat1's Avatar
jerseycat1
7th Gear
Default Dashboard Lights Going Crazy
Hi All,
Today, the dashboard lights on my '19 Lexus ES F Sport all started going off.
The car is running fine otherwise.
only thing i noticed when i popped the hood was heavy corrosion on the red battery terminal.
Could the lights be a result of the battery?
Thanks.
Old Apr 15, 2024 | 05:12 PM
tfischer's Avatar
tfischer
25 Year Member
"Could the lights be a result of the battery?"
Yes.
But it "could" be other things as well.
Have you cleaned off the corrosion? That's easy enough to do, and "could" fix the problem, but either way, it will surely answer you initial question.
Old Apr 15, 2024 | 05:16 PM
mikemu30's Avatar
mikemu30
Originally Posted by jerseycat1
Hi All,
Thanks.
Original battery in your 19? If so, it's time to change whether or not this is the cause of the Xmas tree.
Old Apr 15, 2024 | 07:01 PM
gcvt's Avatar
gcvt
Toyotas are especially known to do things like this when the battery gets low. As each computer module detects low voltage, each can trigger a different warning light.
Old Apr 16, 2024 | 01:05 AM
asadani's Avatar
asadani
Hi All,
Thanks.
Its a possible simple fix. Disconnect only the negative on your battery for 2 mins and plug it back up. You will be back to normal. Let us know if this worked.
Old Apr 16, 2024 | 01:15 AM
es250fsport's Avatar
es250fsport
Do you have the original battery?
Does the original battery in ESs need water top up?
Old Apr 16, 2024 | 04:48 AM
ESh's Avatar
ESh
Can you read the codes? I don't think this is because of the battery.
You will not see these lights if you can start the car, that means there's enough power to crank the engine.
Old Apr 16, 2024 | 09:49 AM
E46CT's Avatar
E46CT
I think a lot of cars are. BMWs are very notorious for throwing warnings after bad connection or low voltage as well.
Old Apr 16, 2024 | 09:57 AM
gcvt's Avatar
gcvt
Oh God yes! My old 550i dash would light up like a Christmas tree if the wind blew in the wrong direction LOL
Old Apr 22, 2024 | 05:27 AM
jerseycat1's Avatar
jerseycat1
7th Gear
Car is still in the shop, they can't figure it out.
Theyve replaced battery and ECM so far.
They're replacing wiring harnesses today. Luckily, under warranty.
mitul1069
Apr 7, 2020 07:56 PM
singletary
Dec 21, 2017 04:28 PM
superdabo
RX - 1st Gen (1999-2003)
Dec 2, 2009 08:03 AM
2jzism
Jun 2, 2009 09:47 AM
