Dip Stick Question
Old Feb 22, 2024 | 09:46 AM
Shaboom's Avatar
Shaboom
Default Dip Stick Question
Does the distance between the two “dots” on the 350 ES dipstick represent 1 Quart or 1 Liter of oil?
Old Feb 22, 2024 | 11:35 AM
grp52's Avatar
grp52
Yes ... for all practical eyeball measuring purposes.
(1 quart = 0.946352946 liter)
Old Feb 22, 2024 | 01:56 PM
ESh's Avatar
ESh
Yes, that’s the case for the most cars.
Old Mar 6, 2024 | 01:37 PM
Fsport19's Avatar
Fsport19
50 years ago, I would have answered one dot (or one line) showing on the dipstick means one-quart (32 ounces) low, and today, agree that when a dot shows on the dipstick, the engine oil level is below full. Since the engine parts are produced in a metric using country, I am inclined to say the dot represents liters.
Old Mar 6, 2024 | 02:07 PM
Shaboom's Avatar
Shaboom
Are the 2021 ES 350 engine parts not produced in Georgetown Ky? Is the car merely assembled there? Is the engine manufactured in Japan?
Old Mar 6, 2024 | 02:40 PM
grp52's Avatar
grp52
Geesh. The things one learns reading the Owner's Manual; specifically page 312 of the 2024 LEXUS ES250, ES350 OWNER'S MANUAL USA AND CANADA ONLY version where there's a better illustration explicitly labeling the two oil dip stick dots:
🄰 Low level mark
🄱 Refill upper limit mark
and more specific, clarifying wording on the oil quantity table:
• Oil quantity (Low level mark Refill upper limit mark)
2GR-FKS engine:
1.9 qt. (1.8 L, 1.6 Imp.qt.)
A25A-FKS engine:
1.6 qt. (1.5 L, 1.3 Imp. qt.)
Old Mar 6, 2024 | 04:06 PM
Shaboom's Avatar
Shaboom
So you’re saying the distance between the two dots (full and add) is NOT 1 quart but rather nearly 2 quarts? Just want to be sure I’m not misunderstanding you. I’m not well versed in all this. Big difference there. I never heard that before but if the manual says it, obviously it’s correct. Just want to be sure I’m not misunderstanding your writing.
Old Mar 6, 2024 | 04:36 PM
Fsport19's Avatar
Fsport19
I believe the parts are made in Japan, yet assembled in Georgetown
Old Mar 6, 2024 | 04:40 PM
grp52's Avatar
grp52
Although the presentation of information isn't quite as clear in the 2019 to 2023 versions as it is in the 2024 version, all the ES 350 Owner's Manual versions have the exact same 1.9 quart listing for the 2GR-FKS engine.
The slight change in presentation in the 2024 manual version makes it really clear - dot to dot is 1.9 quarts for the 2GR-FKS engine.
Don't feel like you're the lone stranger in assuming the quantity between the dots was 1 quart/1 liter. I, myself, was assuming that until I dug into the manual to try and find something definitive to settle the quart versus liter quibble.
Old Mar 6, 2024 | 06:37 PM
Shaboom's Avatar
Shaboom
So if the oil level is halfway between the two dots, then it’s a full quart down. But no NEED to add, according to manual, unless it’s very close to bottom dot “add” mark, which is nearly 2 quarts down! Driving with oil level down say 1 and 3/4 quarts down seems dangerous to me. But manual says no need at that point to add until level is near bottom “add” line, a full 2 quarts down. Could that that actually be correct? Sounds like poor advice from the owner’s manual to me.
Old Mar 7, 2024 | 08:26 AM
mikemu30's Avatar
mikemu30
You're making me nervous - I hardly ever check my oil any longer. Always right up to the full line when I used to check it. I guess I should start again with 70K on the clock.
Old Mar 7, 2024 | 08:46 AM
bc6152's Avatar
bc6152
Two Lexus cars, never added a spoonful of oil between yearly changes in either car. Keep oil level right in the middle...
Old Mar 7, 2024 | 08:52 AM
Shaboom's Avatar
Shaboom
It’s a serious matter because of the dipstick reading is down, say, just 1/4 inch and the space between the two dots is an inch (may be wrong there), then I/4 of the distance from full to add is 1/4 of 2 quarts, being a half of a quart down. To me, that’s of concern, despite the fact that manual says need to add only if close to two quarts down! I dunno….
Old Mar 7, 2024 | 09:01 AM
Shaboom's Avatar
Shaboom
But isn’t ’right in the middle” a quart down on a two quart dipstick?
Old Mar 7, 2024 | 09:06 AM
hotwings's Avatar
hotwings
I would not sweat being 1/4" (1/2 quart) below the top dot although I have nothing to to back that up with.
What surprises me is how if I add the recommended quantity 5.7 qts after draining filter and pan, it's still at least 1/4" below the top dot. I added a full 6 quarts and was still at least 1/8" low. The manual does say the 5.7 qts is for "reference only" which is very odd to me. Why is it not like every other car I've owned, you add what they say and it exactly hits the top dot?
Again, I'm not losing sleep over this, I think from now on I will just add 6 qts and be done.
