Check engine light!
Old Aug 8, 2023 | 08:38 AM
Daniel32m119's Avatar
Daniel32m119
1st Gear
Default Check engine light!
I have a 2019 Lexus es 350 with 70k. I had some check engine light and warnings show up on dash today.. I scanned it at auto zone and the codes that came up are: P0174, P117B and P0505. Also, the vehicle is showing parking support brake malfunction warning on dash. Please help. What all can I do myself in order to diagnose and fix this issue.. shops are expensive :/
Old Aug 8, 2023 | 09:32 AM
2018ES350's Avatar
2018ES350
First research the codes like anyone else would, then do your diagnosis. Do the easiest things first. I’d start by looking for a vacuum leak.
Old Aug 8, 2023 | 10:27 AM
E46CT's Avatar
E46CT
lean on one bank... injector code.. hmm. plugs good? i like to start with basics first. like what are the basic things you haven't done to the car yet for 70k miles
Old Aug 8, 2023 | 11:26 AM
chuyrobles's Avatar
chuyrobles
I would clear the codes and see which one(s) return.
Old Aug 8, 2023 | 01:25 PM
ESh's Avatar
ESh
Vacuum leak, bad injector, clogged air filter.
Clear all the codes and check if they would return.
Old Jun 5, 2024 | 07:54 AM
MrSmoas's Avatar
MrSmoas
2nd gear
I had this happen to me yesterday, at the gas station after a fill up. My mechanic suggested a new throttle body. What was the fix for your car and did it work?
Old Jun 6, 2024 | 12:17 PM
artbuc's Avatar
artbuc
First step is to find new mechanic who can actually diagnose problem. Follow advice already given. Clear codes and see which one comes back first. Sometimes you will see a companion code which has nothing to do with problem.
kimmie7890
Apr 30, 2024 06:35 AM
jeremy1996
Jan 22, 2023 04:26 PM
5LITRV8
GS F (2016-present)
Sep 24, 2022 06:11 AM
3000
57
Jun 3, 2018 04:16 PM
