ES features you did not know about.
#31
Carista
I have Carista, Here are the settings for my '14 ES300h:
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / *5* / 6 / MAX
Beep when opening/closing windows with remote
*YES* / NO
Warn when door can't be locked with remote because it's open
*YES* / NO
Warn when a window is still open when locking doors
*YES* / NO
Warn when sunroof is still open when locking doors
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / *LONG PRESS* / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Auto-lock doors when moving
ON / *OFF*
Lock doors when shifting into gear
*ON* / OFF
Unlock doors when shifting into park (P)
*ON* / OFF
Unlock all doors when driver's door is opened
ON / *OFF*
Unlock trunk when doors are unlocked
*ON* / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Unlock trunk when smart key in range
*YES* / NO
Open windows and sunroof by holding key in door lock
*ON* / OFF
Close windows and sunroof by holding key in door lock
*ON* / OFF
Open windows and sunroof via long-press on remote
*ON* / OFF
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / *WITH DOOR LOCKS* / DISABLED
Lower passenger-side mirror when in reverse gear (req. memory seats)
DEFAULT / *USER-SPECIFIED*
Instruments / Display / Dings:
Engine start indicator
*ON* / OFF
Display odometer after ignition is turned off for…
*30 SECONDS* / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on
*YES* / NO
Seat belt warning ding (driver)
Seat belt warning ding (front passenger)
Turn signal click volume
LOW / *MEDIUM* / HIGH
Lane-change turn signal auto-flasher count
OFF / *3 FLASHES* / 5 FLASHES / 7 FLASHES
Remote low battery warning
*ON* / OFF
Lights:
Daytime running lights
*ON* / OFF
Coming-home lights duration
*OFF* / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
*ON* / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Interior footlight (bright when doors open, dim when driving)
*YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
*YES* / NO
Turn on exterior footlight (on side mirror) when smart key in range
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / *15 SECONDS* / 30 SECONDS
Interior light control
Exterior light control
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
A/C ECO mode
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / *NO*
Deactivate front defroster when AUTO button pressed
*YES* / NO
Fan speed reaches its target…
SLOWLY / *NORMALLY* / FAST
Other:
Roll down rear shade when in reverse gear
YES / *NO*
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / *0.7 SECONDS* / 0.9 SECONDS / 1.2 SECONDS
Slide driver's seat back for easy exit
*OFF* / SHORT / STANDARD
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
ON / *OFF*
*ON* / OFF
*ON* / OFF
ON / *OFF*
*ON* / OFF
*YES* / NO
*ON* / OFF
*ON* / OFF
*ON* / OFF
*ON* / OFF
*YES* / NO
*ON* / OFF
Lights:
*ON* / OFF
*ON* / OFF
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Heater & A/C:
A/C ECO mode
*YES* / NO
YES / *NO*
*YES* / NO
Other:
YES / *NO*
#32
Do NOT buy them on ebay. They're not genuine...
...or name brand batteries. I bought some for my BMW fob (the packaging said 'Panasonic' but they were knock-offs) and guess what? They didn't work properly. I had to use the key numerous times and my comfort access rarely worked. I read something on the Bimmer Post forums about these eBay batteries, went to a CVS and bought a couple genuine Panasonics and end of story! Both my fobs worked perfectly for key-less entry, starting and locking using the sensor on the door handle.
#33
Found more on the web re: Carista - http://www.caristaapp.com/vehicle/Le...20(2013+)/2014
Curious is anybody has given it a try?
#34
This is a great addition. The center storage bin is so deep things get lost in the bottom. With this I put things I rarely use in the bottom of the tray and everything else on top. Great coin holder.
NdYAG (07-28-17)
#35
https://www.amazon.com/Salusy-Consol...r+storage+tray
#38
That makes me wonder if the Amazon sellers might just have not updated their listing in the last 2 years and if it could be the case that the storage tray would actually fit in the 2016 and 2017 ES.
#39
#40
I keep forgetting that the car has a front windshield wiper de-icer (although luckily I don't live in an area where I have to make any frequent use of it). Its control is buried under one of the annoying sub-menus in the climate control system.
#41
Thanks so much for this!
Just got my Salusy yesterday and have to say it's awesome! Yeah, I realize it's not some performance part or anything, but I'm OCD and ADD (kiddingly lol!) and need to have things organized or it drives me crazy! This thing works perfectly and even has a slot to run my charger and/or USB cords through it. Excellent design.
Kudos to you!
Swishbro
#44
I suppose you can, however...
...this thing sits above the area where you would place your CDs, so you would have to lift it up to get to the bottom of the storage area to get to them. I can assure you there is enough room below this unit to store a pile of CDs.
#45
