Running lights blinking.
Old Oct 18, 2020 | 05:07 PM
Interapid's Avatar
Interapid
Default Running lights blinking.
2017 ES 350 ultra luxury, 52,000 miles. Wife comes home and the string of lights just under the headlights are blinking while the engine is running. Engine off, lights quit blinking. I have never seen it do this before. Any ideas?
Old Oct 18, 2020 | 07:59 PM
Interapid's Avatar
Interapid
Could this be a sign that the battery is going out?
Old Oct 19, 2020 | 05:53 AM
bc6152's Avatar
bc6152
Those lights are all LED's. Cross your fingers and hope they're not going south... Very expensive to replace. Is it both sides? Without any other signs that your battery is failing I don't think that's the cause...
Old Oct 19, 2020 | 05:43 PM
jgscott's Avatar
jgscott
Were both driver and pass side blinking?
Old Oct 19, 2020 | 06:14 PM
L3XUSFAN's Avatar
L3XUSFAN
As others said if it was both lights something weird going on, but if it was one headlight only it could be the led's going out. Your 2k miles outside the warranty. Document it and call Lexus corporate, see if they can help you out or cover the repair.
Old Oct 19, 2020 | 08:25 PM
st1800's Avatar
st1800
Check fuses?
Old Oct 20, 2020 | 05:01 AM
Interapid's Avatar
Interapid
Yes it is both sides. But the next morning everything is back to normal. Strange glitch.
Old Oct 21, 2020 | 04:52 PM
L3XUSFAN's Avatar
L3XUSFAN
Probably a fluke, but one long shot theory Is that if the ES350 Parking Brake disables the lights when engaged, is it possible that the parking brake switch was recognizing the parking being engaged/disengaged, which would make the DRL's go on/off repeatedly?
Old Oct 21, 2020 | 05:26 PM
jgscott's Avatar
jgscott
And or it some kinda of warning indicator of a sort.
GFerg
Dec 26, 2020 11:53 PM
GaryJG
Feb 9, 2018 06:47 PM
kennyw418
May 18, 2015 01:31 PM
geoJwD
GX - 1st Gen (2003-2009)
Sep 2, 2008 02:34 PM
e-man
May 14, 2004 11:44 AM
