Lane wander 2014 ES
#32
#33
Count me is with the loose feeling steering. I just accepted it as the normal feel for the car when I bought it in Jan. of this year. My previous car and current beater/dogmobile is an 08 Mercury Milan AWD and it tracks truer with crappy tires that are worn than my 15 ES300 with brand new rubber.
Like a previous poster stated, it does feel like an older Oldsmobile or Buick LaSabre of the early 90's. Mine isn't as bad and I wouldn't call it wondering so much as constant slight corrections. In the Milan I can look at the GPS and know that when I look at the road again I'll be on the same track. With the ES, I don't take my eyes off of the road for more than a split second.
I still love the car though and have zero regrets with my purchase.
#35
#36
I just started experiencing this same issue with my 2014, this is my second 6th gen es350, the 2013, no issue and now the 2014, 2 months ago I don’t have this issues. There is a straight road that I let go of the steering and for about 40 seconds it goes straight and I don’t have to steer, now I feel every 1 second it either veering left or right.
#37
Did you ever get this looked into by the dealer?
I'm starting to feel like there may be something in the steering box assembly or front bushings that is too easy susceptible to being knocked out of spec by hitting a pothole, or just normal driving on rough roads.
I swear, people probably think I'm a drunk driver by how much this thing carves back and forth within the lane. Every other car I drive feels like they track amazingly well. (and my ES has a fresh alignment and Michelin Premiers with 8k miles)
#38
I didn’t do anything, I just got used to it and I totally forgot all about it.
#39
I did hit a deep pothole a short time after I got the 2016 ES350 and it jarred the living hell out of it. I don't remember though if it started wandering before or after that. I want to say before.
For reference, the car would wander to both sides and constantly require minor corrections. If I didn't correct, it would go across the line or off the road at times.
#40
Local Lexus dealer did the alignment and subsequent test drive. They feel it drives normally.
I think they are clearly looking for an obvious pull to one side or the other. This is not the case. It simply never goes straight ... always correcting a bit to keep it within the lines. None of our other cars wander like the ES does.
#41
Other things that go usually before 100k miles - Sway Bar links (all 4), (I already said front Lower Ball Joints, Outer Tie Rods, not sure about inner..), Suspension system (Struts/shocks, strut mounts, bearing, etc.). Without everything being tight, your car does not handle or steer well, and does not feel stable. Another thing I am considering Front wheel bearings, and eventually - front control arms.
#42
You don't indicate the model of Acura, but my Mom had an 07 Acura TL, rode like a log wagon from day one with OEM tires, and the replacements. I put some Michelins on it and it rode better but still in the log wagon catergory IMO .Two different suspensions except for the overall design. Acura's have a stiffer/sportier suspension IMO, while the ES has a softer/floatier ride.
morgan1819
ES - 6th Gen (2013-2018)
28
08-06-17 06:03 PM
nivla
ES - 5th Gen (2007-2012)
06-29-11 06:56 AM
