Lane wander 2014 ES
2014 ES. Requires constant correction. Can never simply hold a line without steering input. Even on non-windy days. Really bad if windy. All of the other cars in our family track straight with no issues.
Michelin Premiers with 10k on them. 36psi all around. Attaching photo of latest alignment by Lexus. Anyone else been down this road ... and found reasonable solution? https://cimg8.ibsrv.net/gimg/www.clu...858fd0a5ae.jpg |
Google to see if those tires have a soft or stiffer sidewall, which could lead to the problem/issue.
I have Michelin Premier's on my wife's Acura, and it tracks perfectly.
is that chart before or After Alignment? Toe being out of whack, which it appears to be , WILL cause wandering issues.
Originally Posted by st1800
(Post 10496579)
Ask the dealership to see if their alignment rack is calibrated. Then ask them to take the camber bolt out, clean the holes and then try to do the alignment, had this same issue on our CR-V, which was fixed by reseating the cam bolt. you can also get more Highway stability with more positive camber in the rear.
Originally Posted by morgan1819
(Post 10496607)
Top section is before, bottom is after. (It is labeled)
I tried to to find the factory alignment specs to cross check them, but couldn’t. Were you having the problem before and after alignment? Good luck. |
(Post 10496693)
thats what I get for reading on my (ancient) phone. Lol.
I tried to to find the factory alignment specs to cross check them, but couldn’t. Were you having the problem before and after alignment? Good luck. But yes, was an issue before alignment, and still wanders after. Looking for suggestions. |
Originally Posted by john341
(Post 10496610)
This car could absolutely use more hwy stability. Zero 'on center' feel when cruising. Constantly back and forth, and gets pushed around by wind. |
Did this wandering start after getting the new tires? Check to see if the tires are mounted on the wheel the right direction. Lot of stability issue can be caused bad tires, so check the tires are good quality even if they are Michelin. Tire pressure can also cause wandering.
(Post 10496793)
(Post 10496450)
Originally Posted by JimInTN
(Post 10497097)
You don't indicate the model of Acura, but my Mom had an 07 Acura TL, rode like a log wagon from day one with OEM tires, and the replacements. I put some Michelins on it and it rode better but still in the log wagon catergory IMO .Two different suspensions except for the overall design. Acura's have a stiffer/sportier suspension IMO, while the ES has a softer/floatier ride.
Only the ES requires constant steering correction. |
Did the alignment improve it at all, or is it just as bad after as it was before?
Did you just purchase this car? If not, when did it start happening?
