Figured out why my speakers were sounding so empty and no bass
issue is not loudness tho, best way i can describe is that on bluetooth my audio sounds like a non-hd fm radio station. and then via usb it sounds much richer, as if HD was turned on FM station
You asked us to do the comparison test for you and we did. Now I ask you to check the Bluetooth volume setting. How about you just do it rather than hypothesize why it should not matter?
so, i brought both bluetooth and usb to same levels of volume, for the sake of this test i did volume level 40.
Surround is on and off, i tried both ways.
Then same volume on my iphone XR, about middle for both blue tooth and usb.
there's still a significant difference in how the audio plays, bluedtooth audio just feels like itt's missing something. i'm not an audiophile, so i can't correctly describe it. my best description is when you first turn on fm radio before the HD signal is captured, that's how my audio over bluetooth sounds. Then you know how when your radio catches the HD signal for the station and it suddenly sounds a lot better? that's the difference between my bluetooth audio and audio connected to iphone via usb
ok, had to wait to finish work before testing this.
Then same volume on my iphone XR, about middle for both blue tooth and usb....
hisstojay (02-13-19)
Recently got a 17 es service loaner. Thought that the stereo was absolutely terrible until I realized that my phone volume was reduced when I connected it to Bluetooth. Adjusted it via buttons on side of phone and there was a dramatic improvement.
" Then same volume on my iphone XR, about middle for both blue tooth and usb. "
strange issue really, but usb works fine so i'll leave it at that
If I am not mistaken when you output via USB the phone's volume setting doesn't make any difference. You are essentially sending a digital signal to the car's head unit bypassing the audio circuitry in the iPhone. When you output via Bluetooth on the iPhone the volume level on the phone does come into play. It takes the phone's amplified signal, converts to bluetooth and sends that on to the car where it's converted back to an analog signal and amplified by the head unit.
my other guess is that maybe the audio over bluetooth gets compressed and thus it looses some of the clarity from the source. but this is me talking out of my A$$ as i'm not an expert in this field
Not sure why is it hard to understand but let's try again. Set Bluetooth volume on the phone to MAX. Set the volume on the car to be the same - e. g. to 40 on BOTH Bluetooth and USB sources (each source has it own adjustment and it remembers it). Set the automatic volume leveling to off on both sources.
Also you may want to check settings in the app that plays music on your phone to make sure it does not do any additional processing of volume leveling.
FWIW, on the ES, the volume is independent based on input, for example if I have the usb on 20 and switch to Bluetooth and put it on 30, when I go back to usb it is on 20 again. If you are raising the volume on usb and then switching to Bluetooth, make sure to adjust that volume as well.
If you set the Bluetooth sound on your phone to "MAX" and it sounds noticeably different than when connected via USB, you should take it in and have it fixed. Are you still under warranty?
I have a 2018 ES 350 and I also notice a clear difference in between USB and Bluetooth. Phone volume in both cases at 100%, volume on the car with both sources at level 18 and listening to music at 320kps. Via USB the music is much clearer and bass is tighter.
Isn't volume value 18 kinda low?
volume 18 in car is pretty high when the volume is set to MAX on the phone.
so, i did try your suggestion yesterday night. MAX volume on iphone via bluetooth and usb as well.
Same issue, audio over bluetooth sounds kind of shallow vs usb. And yes DSP settings exactly the same on both usb and bluetooth.
i did some searching on google, this is what i could find:
audio over usb in the case of iphones = iphone internal processor converts digital to analog, then analog gets converted back to digital by signal processing in car headunit. NO LOSS OF SIGNAL/DATA during this process.
Audio over bluetooth = gets compressed one more time (i'm assuming this for mp3s, since they are compressed already). This might be the reason i notice sound quality difference between the 2.
I will try it with iPhone later today. I think it works differently on android.
