2016 Lexus ES350 Dashcam hardwire install
Just a small update. I was able to utilize my dashcams 24hr parking monitor feature by tapping into a different line than the one described by EJC and keelaboosa. I used a volt meter and found a few different lines that were live 12v with the engine turned off. Sorry I wasn't able to snap up some pictures as I was in a hurry, but I ended up using the line next to the beige color wire that keelaboosa posted in his picture, but my wire wasn't red like you can see from keelaboosa picture. I would HIGHLY suggest using a volt meter with a sewing pin tapped to the end to access and confirm the voltage of the wire you plan to tap into to. It has been almost a week and there has been no issues. Btw, I didn't sodder the wires and instead used T-taps and made sure the connection was fully secure which I feel is a cleaner install and can be later removed if needed.
Thanks to all for the original video identifying the correct connector, and the photos showing the actual wires themselves. I was a little confused when I checked the voltage before spicing as turning off (pressing the button) is a two step process with the doors open. After the first press I still had voltage on the tan wire, but after the second press it dropped to zero. There was enough room to shove the excess cable/voltage regulator above the console and it snapped back into place without any issue. Now works perfectly without the cigarette lighter adapter hanging down!
EJC (01-27-20)
Hello all,
I just ordered the Aukey DR02D front and rear camera for my wife's ES300H. They come with a 13ft USB Mini-B Cable and 23ft USB Mini-B Cable. This should be enough to tuck wires and run them both into the arm rest where the USB connectors and cigarette lighter is, correct?
Hello all,
Do you have parking mode with your dash cam? I'm also wondering if it's safe to leave the camera plugged in and "on" every night. I don't want to drain the car battery, so I thought about getting an external battery pack which would require us to plug in every night when we get home from work. Bit of extra work, but I don't mind. We are in an apartment and there were some break ins last week, which prompted me to get this camera. I want to be ready to catch these crooks in case they ever come back.
Hello all,
Will attempt this tonight! Ordered it 30 min ago and it's already saying that it will be delivered today!
But check the specs the camera should be working on its' internal battery and should wake up when bumped. This way the battery should not drain.
On the Lexus, the convenience outlets are dead with the ignition off (unlike Porsche which are always live).
You will probably be fine.
