Braking Power Low
We got for 2017 ES 350 few days ago .Today pumped out brake fluid from reservoir and add new (reservoir was overfilled ) after adding fluid i got braking power low light come up . Battery good ( tested ) car drives fine , brake pedal not soft not hard and brakes works fine . Not sure what else can be , need help please
How did you "pump out the fluid from the reservoir"?
You never want to empty it as that will introduce air into the brake lines.
The correct way is to use a syphon or turkey baster to remove as much fluid as you can, then fill it with fresh fluid, then open each wheel bleed screw one at a time to change the fluid. Using a vacuum pull tool pull the fluid through works very well. The old school method with a friend pumping the brake pedal is asking for trouble.
It may be time to bleed your brakes properly. Or pay a shop to bleed your brakes.
thank you
Another option is Launch:
https://www.amazon.com/LAUNCH-Bi-Dir.../dp/B0D176ZCXQ
The NT510 Elite is still available, and there's a NT530 model that is also bi-directional, but if I were to buy another Fowxwell, it'd be the NT710, which is much advanced, has online downloads and updates, and has a faster processor inside. I've absolutely no experience with Launch, but I can recommend the Foxwell brand, enthusiastically (it's a favorite on the Xoutpost.com site).
