USB stopped working. Where ids the fuse ?
hi all,
Car is a 2018 ES 350 and both USBs no longer read USBs when they are plugged in. I am looking to try and replace the fuse, but cant find it.
Nothing on ClubLexus or online, or in the Owners Manual showing where the fuse is .... anyone know ?
Thanks
Thanks
What do you mean by "reading usb"? Are you using a usb flash drive trying to play music from it? Did the issue begin out of nowhere with the same usb that was previously playing? Or have you decided to try to play an old usb drive you found on the road and it's not "reading"? Have you tried known good usb flash drive that has a simple folder or simple mp3 file on that would play on another car but wouldn't play on your system?
I doubt there is a fuse for usb specifically, it's probably your audio unit's issue. However, you can verify if you get power there by inserting a lighted usb flash drive or flash light.
Have you checked your fuse box? The diagram should be in the manual. Google 2018 lexus es 350 owners manual pdf, and you will find it.
