Headlights- Can I use LED lights?
Old Sep 30, 2022 | 05:06 PM
IoT's Avatar
IoT
Default Headlights- Can I use LED lights?
I have Lexus ES350 2010 model and it has Halogen bulbs for beam (low, high) and fog. Pictures are attached.
I have following questions:
1. Can I use HID or LED lights?
2. Is Yellow light (Halogen or HID) better for driving in heavy rain and or fog (day, night) or white light works fine?
Planning to install yellow light for fog and low beam and white light LED for high beam.
3. What is the brand you would recommend for Halogen, HID, or LED lights?
4. Someone mentioned that ECU temperature (low high) has to be modified if LEDs are installed?
Old Oct 22, 2022 | 12:08 PM
heidihidin's Avatar
heidihidin
Not a mechanic and speaking strictly from experience.
Yes you can use LED bulbs. No you do not need to modify the ECU.
To me cool white is the best color.
I used PIAA bulbs, plug and play.
Old Oct 23, 2022 | 08:29 AM
ESh's Avatar
ESh
I also put leds on high beam and they are so bright. Plug and play.
Old Dec 20, 2022 | 09:17 AM
lostinthew's Avatar
lostinthew
Default LED retrofit bulbs
I have a 2007 ES350 and would like to switch to LEDs. Can anyone recommend the correct bulb replacement and brand for the H7 OEM bulbs? Are they plug and play? Any advice?
Thanks in advance.
Biglex978
Jun 25, 2019 11:26 AM
Luscombe8A
Jun 17, 2018 07:27 AM
organa7
Jan 21, 2016 05:24 AM
edmondt
Mar 21, 2013 12:19 PM
exmeaguy
Lighting
Jul 7, 2009 12:35 AM
