Intermittent brake light warning
Old Apr 28, 2021 | 09:48 AM
Rogarven's Avatar
Rogarven
Default Intermittent brake light warning
My '09 ES 350 is showing a brake light failure but only once and a while. These would be the original bulbs and I did check that the left one was out but yet the light will not always show it. I am not sure if the light was out when the failure light was not on. I am curious and before I go ahead and change it ( I bought the bulbs) , I wondered if anyone had any ideas why it doesn't stay on all the time. Thanks for your reply.
Old Apr 29, 2021 | 07:45 PM
Hayk's Avatar
Hayk
The warning lights operate on electrical resistance. It all depends on how the bulb failed, if the socket is okay, and whether the wiring is in good shape. If the warning stays on with the bulbs out, then you shouldn’t have to worry.
Old Apr 30, 2021 | 08:50 AM
Badhobz's Avatar
Badhobz
mine did that. said brake bulb failure even though the brakes were working fine. Then one day, it did die, i replaced the bulb and its back to normal now. Its a pretty advance system, probably detects drop in current or something because it knew that bulb was on its way out.
Old May 5, 2021 | 03:34 PM
Rogarven's Avatar
Rogarven
Thanks for these responses. I will try replacing the bulb as I bought 2 at Auto Zone and see if that solves it. Just strange how it is intermittent.
2gsAlex
Jun 6, 2019 11:02 PM
gaz209
RX - 3rd Gen (2010-2015)
Jun 11, 2017 02:07 PM
LexusK
May 6, 2016 01:47 PM
uplusd
Apr 5, 2007 10:06 PM
nysupraman
RX - 1st Gen (1999-2003)
Jun 1, 2005 12:37 PM
