No power to dash or push start
Old Mar 14, 2021 | 01:50 AM
Shan2015's Avatar
Shan2015
Default No power to dash or push start
2008 es350 bo power to dash or push start I have replaced fusible link both of them still no power I replaced the fuse box inside no fix I check most graunds under the hood inside the car those are visible to some point I checked all fuses number 26 a/f fuse no power efi1 and 2 show low voltage need some advice I know its something simple bugth the car from a friend so I dont have to much history about it any advice will be appreciated and yes battery is good over 12.4 volts
Old Mar 15, 2021 | 08:17 AM
Clutchless's Avatar
Clutchless
First try a different battery or a jump start to see what happens. The battery may still be too weak to power stuff.
This thread on the RX forum is sort of similar and may be of some help with diagnostics
https://www.clublexus.com/forums/rx-...-but-dead.html
Old Mar 15, 2021 | 01:42 PM
ESh's Avatar
ESh
Is there a light on the start/stop button?
Old Mar 16, 2021 | 01:43 AM
Shan2015's Avatar
Shan2015
[QUOTE=LjeksesES;11013394]Is there a light on the start/stop button?
no power to push start also no power to dash... lights inside comes on door will unluck and lock the car trunk and horn works headlights coming on just no power to dash or the start button
Old Mar 16, 2021 | 02:30 AM
ESh's Avatar
ESh
I think the problem is the button itself.
Old Mar 16, 2021 | 06:44 AM
Clutchless's Avatar
Clutchless
That was the problem with the RX in the link. He had ordered a new one, but that was the last post.
Old Mar 18, 2021 | 01:55 PM
Clutchless's Avatar
Clutchless
The guy with the RX350 installed a new start button and it did not help.
Old Mar 18, 2021 | 10:41 PM
Shan2015's Avatar
Shan2015
Default Half
Thanks to everyone that posted a comment I got power back to dash and strat button I took the dash out I found the ecu I'd code its behind the heat and ac very hard to get to even with the dash out I got one from the junkyard and installed it also there some kinda circuit fuse is under the dash behind the cluster it was burned I think I might of did that with the tester given power to some wires and relays now my problem is no crank no start I got locksmith Came and tried to program it the key unluck and lock the car but no crank no start scuriry light flushing he did a some kind of flash or programming that take 16 minutes he tried 2 times no luck Also we did the obd connector pins for 30 minutes I try 2 times all lights flash in dash for 30 minutes still no crank no start I know push buttons good starter is good all relays and fusible link and fuses good I think I might need to get a new ecu I'd box and a new key and see if its going to work but any advice still welcome hopefully this Will help others in future
Old Jan 4, 2023 | 03:12 PM
Paullock's Avatar
Paullock
4th Gear
Hello please can you tell me what you did to get power back to dash and start button?
Old Jan 4, 2023 | 03:52 PM
Paullock's Avatar
Paullock
4th Gear
Old Jan 5, 2023 | 05:26 AM
Paullock's Avatar
Paullock
4th Gear
Default Please tell me how tou fixed issue
pLease if yo see this can you tell me what was causing all the issues.
Old Jan 5, 2023 | 05:27 AM
Paullock's Avatar
Paullock
4th Gear
Old Jan 6, 2024 | 08:52 PM
lexomatical's Avatar
lexomatical
7th Gear
Red face
can u please tell me how u got power back to dash, was it the id code computer? and a fuse behind the cluster????????
Old Jan 6, 2024 | 09:25 PM
lexomatical
7th Gear
did u fix ur lexus?
please help if anyone knows got this lexus stuck in my shop, 08 gs350, was testing vehicle after ecu replacement, recoded vin and align the sytem, got key working and all looked great, i tested the igntion on and off a few times and on the 3rd time i turned it off, after that no response like cluster went ghost, no messages on dash , just door light when opened, all fuses were clean and tested, relays checked too, battery is fully charged at supply 14.5v no comm ecu, no igntion, seats move only, interior light work, hazard lights work, headlight work, when switched to parking, only backlight light up for nav buttons and trunk/gas illuminate green. green light on switch turns on only if i switch lights on. the cluster does not light up at all, i can send power to ignition fuse 10amp first one in row and lights up the dash with tester power applied. everything was working just fine. felt like last time i turned ignition off, steering retracted back and flet like it didnt go all the way in and just shut down. after that i got no response , i was able to scan the immobilizer and found no errors there, showed key in the sytem, but i cant access pcm. brake lights also work. really got me stumped, also replace the ignitio starter switch, car just hit 100k miles.
Old Feb 15, 2025 | 02:49 PM
larrykessl's Avatar
larrykessl
Originally Posted by lexomatical
did u fix ur lexus?
did you ever figure this out? I’ve been having this issue in and off for two years. Super stumped
rx20info
RX - 4th Gen (2016-2022)
110
Nov 9, 2023 03:49 PM
jerlands
31
Mar 19, 2021 02:51 PM
m5rahul
RX - 3rd Gen (2010-2015)
17
Jul 5, 2019 08:09 PM
Turismo
Jun 20, 2017 03:00 PM
buggsc3
Jan 12, 2007 05:49 AM
