Rear window shade
Rear window shade
The rear window shade on my 2008 ES 350 has stopped working. Is there a fuse I can check, and where is it located? If not, how do I find the problem?
There’s a fuse, over the left drivers leg.
Broken Rear Window Shade
https://www.clublexus.com/forums/gs-...l#post10449006
It could be that one or more of the rear window shade motor gear tooth/teeth broken blocking the motor. In my case, after I removed the two half broken teeth pieces, the motor working ok again.
