Pulling to the right and steering vibration?
I have a 2010 Lexus Es350, and I am having this issue:
When accelerating hard, the car will aggressively drift to the right. During normal driving it is otherwise fine.
When braking from 60-70mph, I will also get a significant vibration in the steering wheel.
What can be the issue here? I've read possible brake rotor, tire out of balance, alignment?
Are these 2 issues connected?
First, if it hasn't already been done.......rotate the front wheels to the back......inspect the tires for uneven tread wear/condition while you're at it. Ensure that they are all properly inflated. Drive the car and see if anything has changed. Report back.
I took my 08 in for 60k service (@ 65k.. oh well) and they performed a lot of service - but a few were not on the original list for 65k. Notably:
turn front rotors
Grease/lube all caliper slides
replace front brakes
Now no more shaking from the rotors, but I have a tire or two that is out of balance (vibration at certain speeds, doesn't get worse/go away with brakes, so it isn't the rotors getting warped again...)
turn front rotors
turn front rotors
turn front rotors
rsxtc
Suspension and Brakes
08-19-05 10:58 AM
