Well, i've left the module alone for a while on the floor mat, but i need a good place HIDDEN so not on the glove compartment, where do you hid this big module in an already squeezed dash ???
When I did an installation on a Friend's RX350, I was able to get the entire thing behind the head-unit. It took some time, but it all fit. The only visible part was the exterior XM antenna.
i have the ML radio on my car, but along with the wires behind, i don't think i can squeeze it in. One option that require alot of work would be mounting it under the big whole radio/nav unit, but it necessitate to remove that unit out.
Do you have some play with the cord in that location since i often remove the radio/nav unit for some work. How did place the unit on: velcro or screws.
Yes, you have to remove plastic trim to access this location. I have around 6" of cable to play with in my location. I did use heavy duty industrial velcro for mounting.
