oil change help
Old Nov 24, 2007 | 09:20 AM
Katie28's Avatar
Katie28
Default oil change help
I need to change the oil on my '07 ES350. What is the torque of the oil drain plug? Thanks.
Old Nov 24, 2007 | 10:21 AM
1993ES300x's Avatar
1993ES300x
just tighten it to a point where it won't leak... you don't need to set foot pound on the plug...
Old Nov 24, 2007 | 03:14 PM
<VENOM>'s Avatar
<VENOM>
just spin it on by hand until it's tight then use the wrench to snug it
Old Nov 24, 2007 | 03:36 PM
larrynimmo's Avatar
larrynimmo
You dont want it to be any tighter than a 10 year old girl could tighten it with a 12" wrench.
Old Nov 24, 2007 | 05:55 PM
kingofire's Avatar
kingofire
15ft/lb if my memory is correct
Old Nov 26, 2007 | 12:31 PM
toneman's Avatar
toneman
Now if only the oil filter housing cap was tightened on as low as that--man, even w/ the oil filter cap wrench I could not apply enough torque to loosen the cap w/o the cap wrench slipping around the cap itself.
Old Nov 26, 2007 | 04:34 PM
larrynimmo's Avatar
larrynimmo
You need a band type of compression oil filter wrench. Lots of those cap wrenches just wont grip
Old Nov 26, 2007 | 08:06 PM
kingofire's Avatar
kingofire
Especially with the way the new oil filters are located, the cap wrenches are hard to use.
Old Nov 28, 2007 | 04:21 PM
trum1110's Avatar
trum1110
Default Oil filter
Hi All,
I seem not able to find the oil filter even looking straight up from down under where the oil pan position. Does anyone have a picture to show ?
Thanks
Old Nov 29, 2007 | 11:47 AM
toneman's Avatar
toneman
Can you recommend a particular/specific one and where I can buy such a wrench? I tried one of those adjustable rubber strap ones--there's just not enough clearance to situate the strap around the canister so that the wrench handle will turn freely.
Thanks!
Old Nov 29, 2007 | 12:01 PM
toneman's Avatar
toneman
Originally Posted by trum1110
Hi All,
Thanks
It's the roughly 2 3/4" diameter round cylindrical-like object w/ a small square opening (IIRC 3/8") in the center of it, located underneath and near the front right tire. If you see something that looks like how a metallic-looking/colored oil filter hanging upside down (or right-side up?) would look like--then you've found it.
Old Nov 29, 2007 | 10:59 PM
<VENOM>'s Avatar
<VENOM>
http://members.***.net/n0v8or/avalon_oil_change.pdf
9146fan
Jan 7, 2017 07:39 PM
lexus-is2
Dec 3, 2013 01:17 PM
longlexus3
Maintenance
Apr 14, 2013 08:23 PM
rftuck
RX - 3rd Gen (2010-2015)
Feb 17, 2013 10:12 PM
tractng
23
Nov 17, 2012 09:23 AM
