Windshield washer failure
Old Nov 9, 2022 | 10:09 AM
babyduke's Avatar
babyduke
Default Windshield washer failure
For 2009 ES350
Windshield washer stopped working on passenger side and now the driver's side. I don't hear anything when I turn it on. Does this mean I need to replace the pumps? There is 1 on each side, correct?
Old Nov 9, 2022 | 11:17 AM
Clutchless's Avatar
Clutchless
First get a pin and try to clear the nozzles that spray the windshield as they can get clogged. You may have to remove the hose and clear it with compressed air.
Then have a friend listen (with the hood open) as you operate the washers and hope they hear the pump operating.
The good news is that it is not hard to replace and they are on ebay for under $40 the same pump is used in many Toyota-Lexus models.
https://www.ebay.com/itm/28496685099...3ABFBM3r6E3Yth
Old Nov 9, 2022 | 12:21 PM
babyduke's Avatar
babyduke
Thanks. I don't hear anthing so I assume the pump needs to be replaced.
So there's just 1 pump?
https://www.youtube.com/watch?v=yl8_FqkfhNo
Old Nov 9, 2022 | 01:39 PM
Clutchless's Avatar
Clutchless
One pump. It is attached to the fluid reservoir. The video helps you locate it.
babyduke
Jun 5, 2022 12:27 PM
mchateau
May 22, 2022 09:20 AM
restcon
Jul 19, 2020 06:11 PM
greasehead
Apr 29, 2015 02:43 PM
Cyclenby
Aug 18, 2010 05:08 PM
