Speedometer and Odometer Issues
Old Aug 16, 2022 | 03:25 PM
Maru667's Avatar
Maru667
1st Gear
Default Speedometer and Odometer Issues
Just recently bought a 97 ES as my first car from someone in my neighborhood. The car has 208,000 miles and passed inspection in January. I have been having an issue with the speedometer and odometer. Every 2-3 days the odometer stops working, and while the speedometer will light up, it does not move. The check engine light also appears. This is fixed by unplugging the battery and then plugging it back in. However, it is pretty annoying to have to pop the hood and do stuff with the battery every few days. When the issue arose for the second time, I went to my work and ran a code scan on the car. I got three codes (All P0500 codes). They all said Vehicle Speed Sensor A. The codes go away after i unplug the battery (I'm assuming that resets the computers). I was told the issue is either my speed sensor (Which honestly I don't know very much about), or my cluster. Does anyone have any idea of what could be the issue?
Also, is there a way to get like a GPS speedometer that is external? Obviously repairing the speedometer of the car would be preferred but I just need a way to be able to determine my speed.
Old Aug 16, 2022 | 03:44 PM
This company repairs clusters
https://www.taninautoelectronix.com/...luster-repair/
It could be your speed sensor as well but the intermittent nature points more to the cluster. In the mean time use a navigation app on your phone they display speed, not ideal but better than nothing.
Old Aug 16, 2022 | 04:53 PM
Arsenii's Avatar
Arsenii
Hello,
It is a pretty common issue for those cars, here is a thread that explains the basics to check before shipping the cluster out. In short, your car still has sensor in the transmission, check that it outputs the signal and it gets to the cluster, if so, you will either need to repair your cluster, or get a used one, but there is no warranty that this issue will not repeat itself again.
Try tapping the cluster when it stops working, I've had a car with a similar issue, and when i would tap on the cluster, the speedometer would come back alive. If nothing else, it would definitely verify if your cluster is bad.
Hope this helps and best of luck!
jaredmac11
34
Oct 16, 2025 09:38 AM
glenpointe
RX - 1st Gen (1999-2003)
Nov 13, 2021 06:52 PM
brendino
Oct 5, 2020 02:34 AM
horton
Apr 15, 2014 09:25 AM
Lexus Boy
GS - 1st Gen (1993-1997)
Sep 5, 2006 09:55 PM
