2007 ES intermittent start failure
Old Mar 24, 2022 | 02:17 PM
mmcd's Avatar
mmcd
10th Gear
Originally Posted by mmcd
You are correct, I now have a 18 page rolled system diagram, i was able to do a little experimenting with the car:
  • The battery was down to 11.97v. The orange wire from certification ECU is probably either VC5 from the ignition switch or LIN from main ECU. After touching with 12v from battery: wire has a clip now one side had 2.25v declining to 1.97 over a few minutes and11.22 on the other. When connected 7.25v. Key fob would not open doors, no ignition light on depressing brake pedal even holding fob to switch.
  • Put car on charger, battery 13.18v, orange wire 2.35v and 13.21v with 8.2v combined. Ignition and door locks not reacting (no light or action).
  • Held fob to switch and got beep and white light on ignition
  • Minutes later got orange light and key not detected on dash
  • Tried touching fob to switch again, got green light and car started but still can't lock/unlock doors or trunk
  • Left car and got beeps about key missing, put fob on steering wheel and fault went away
  • Double checked by leaving car with fob on steering wheel then removing it through window
  • Turned off car and now fob works and engine starts. Battery charged up to 12.53 volts
Any thoughts on this strange situation?
Thanks
Additional data: I could use the fob to lock/unlock the doors today but the ignition light would not come on even with the key next to the switch. Wouldn't this imply that the certification and code ID ECU are working? The battery voltage was down to 12.08v. I got a reading of 5.4v on the orange lead, 11.1v. on one side and 1.19v on the other. Car will start if battery is at 12.53v but no light if 12.08v and loses key recognition by 11.97.
Old Mar 25, 2022 | 08:47 AM
nevernu's Avatar
nevernu
The solution lies in one of these! I'll leave it to the student to complete the proof...
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 8, 2026 | 03:57 PM
larrykessl's Avatar
larrykessl
I have a problem where occasionally the start button will not light so I can't start the car. The fault I've seen is B2799 (immobilizer). I've had a mechanic look at it and try many things. It appears to be a voltage or ECU issue.
  • If the battery is fully charged (12v+) it starts, otherwise no light when brake depressed.
  • The orange lead (MREL I think) to the certification ECU reads about 10v when disconnected from the ECU and 5.25v when connected
  • The start light does not come on and the voltages are about the same on the orange lead. If 12v from battery is connected to orange lead for a moment everything works again
The mechanic has spent a good bit of time with Lexus tech support and they're thinking 1 or more of 3 ECUs which is a bit expensive.
Any thoughts?
did you ever figure this out? I am having a similar issue; no led light on ignition and no door ajar light. Dash dead. I used to be ankecto wake it by touching 12 volts to the Lin line, but not any longer. I fear it’s my impossible to access ID code box
Old Mar 8, 2026 | 05:28 PM
mmcd's Avatar
mmcd
10th Gear
Default ignition key failure
No, managed to sell car at discount since nearest lexus dealer is now hours away. After the LIN method failed I found clicking lock/unlock on the fob worked for some months but then that failed. It's some intermittent on 1 of 3 ECU boxes buried behind the dash.
Originally Posted by larrykessl
did you ever figure this out? I am having a similar issue; no led light on ignition and no door ajar light. Dash dead. I used to be able to wake it by touching 12 volts to the Lin line, but not any longer. I fear it’s my impossible to access ID code box
Old Mar 8, 2026 | 06:16 PM
larrykessl's Avatar
larrykessl
Thanks for the reply. It’s ridiculously complicated on these cars. I’ve spent major $$ and hours and got nowhere. It goes on the sales block later this summer after I reassemble what I took apart.
thanks again
jehmin
Maintenance
16
Dec 12, 2024 12:14 AM
loliwin55
Mar 14, 2022 09:54 PM
Maxamus
May 6, 2020 06:15 PM
ErikTande
Jun 3, 2017 07:27 AM
valgs350
Jun 10, 2008 03:33 PM
