Engine coolant reservoir
Old Jul 26, 2021 | 06:27 AM
Musta75's Avatar
Musta75
Default Engine coolant reservoir
Hello every body
I would like to know that water goes up the full mark in Engine coolant reservoir. Is that normal?
Thanks
Old Jul 26, 2021 | 09:18 AM
Arsenii's Avatar
Arsenii
Hello,
Here you can find a section of the Owners Manual for your car that tells about the coolant. Coolant level is designed to rise as the engine warms up, that is the way a cooling system is designed to work, so as long as the coolant doesn't go over the top, it should be fine.
Hope this helps and best of luck!
jsferra
Oct 11, 2023 10:09 PM
Sudanid
Jun 10, 2021 11:25 AM
Prajash
Sep 6, 2017 07:47 PM
Peker
Jul 21, 2014 01:44 PM
rtk7
Sep 30, 2007 07:10 PM
