At My Wit's End
Subscribe
Jan 19, 2021 | 08:48 AM
I have a '95 ES300... Ive had it about 2 years and I absolutely love it. It only has 137.8 on it. Im having a HUGE issue with this one problem. Ive replaced fuses and tried every "solution" I could find.
That being said, my problem is this: My interior lights... Floor board, dome/driver center and mirror lights wont turn on and my power door locks dont work. I also cant use my key fob with the simple button on the side to lock or unlock. As I said I've replaced the fuses already and tried all the solutions I found and none have worked. What could be causing this?
Reply 0
Jan 19, 2021 | 09:39 AM
Did you test with a volt meter? Examine the DOME fuse especially. Any chance there is rodent damage?
Reply 0
Jan 19, 2021 | 09:43 AM
Hello,
It seems like a power issue, since all systems to which the fuse belongs are affected. You said you checked the DOME fuse, but have you tried swapping it with a different, verified one? If that won't help, use a test light to check if you actually have power coming and leaving the fuse, you can use exposed leads on top of the fuse to do so.
Hope this helps and best of luck!
Reply 0
Subscribe
