Warning lights- panic
Old Aug 6, 2020 | 08:46 PM
mrlexus12's Avatar
mrlexus12
Default Warning lights- panic
Hey guys
so when I press the start button twice without pressing on brake pedal to enter ignition ON mode, i notice few warning lights that come on in instrument cluster. Owner Manual says these light should go away after a while but my warning lights stay on. Is something wrong? Is my car malfunctioning ?
Old Aug 6, 2020 | 08:50 PM
john341's Avatar
john341
Those should go away when the ignition is onn.
Old Aug 6, 2020 | 09:11 PM
mrlexus12's Avatar
mrlexus12
This is what I am seeing.
Old Aug 6, 2020 | 09:18 PM
john341's Avatar
john341
Ignition is not on, hence the reason for those lights. Start the car and it will go away after about 1.5 seconds. If there is anything majorly worng with the car, you will see a written warning message on the display between gauges.
Old Aug 6, 2020 | 09:23 PM
john341's Avatar
john341
mrlexus12's Avatar
mrlexus12
yes when the engine is turned on the lights go away.
The “ignition On” is when you press start button twice without pressing brake and it allows you to run fan and audio without starting engine and Owner Manual says in this mode the lights should go away too....
Old Aug 6, 2020 | 09:37 PM
john341's Avatar
john341
You are right my bad on the "Ignition On" phrase; what I mean is start the engine. if the lights do go off when the engine is running, I don't think you have anything to worry about.
Old Aug 6, 2020 | 10:26 PM
mrlexus12's Avatar
mrlexus12
thanks.
any other guys can take 5 seconds and check on their cars and report to me if these lights are normal? Will appreciate guys. Please check the photo I posted for reference. Do you get same lights constantly on in the ignition ON mode ?
Old Aug 7, 2020 | 02:18 AM
rmak's Avatar
rmak
Originally Posted by mrlexus12
thanks.
I never even pay attention unless the engine is running.
Old Aug 7, 2020 | 03:42 AM
NdYAG's Avatar
NdYAG
My dash after two start button presses w/o holding the brakes:
Old Aug 7, 2020 | 07:16 AM
mrlexus12's Avatar
mrlexus12
thanks. Do the lights continue to stay on or disappear ?
it seems this is normal in our cars.
Old Aug 7, 2020 | 07:39 AM
NdYAG's Avatar
NdYAG
The lights stay on. This is normal in ALL cars in "ignition on, engine not running" state. Initially the purpose was "bulb check" - which is less needed nowadays with transition to LEDs.
whatnext
Jul 31, 2015 05:55 PM
khizr23
May 5, 2014 11:22 AM
retired
Jan 17, 2012 06:50 AM
jerryray
RX - 3rd Gen (2010-2015)
May 29, 2011 10:52 PM
t70 supra
Oct 19, 2006 09:54 AM
