Valve Stem Seals Color Code?
Old Apr 28, 2019 | 01:00 PM
whiskywine's Avatar
whiskywine
Default Valve Stem Seals Color Code?
About to install new valve stems on my 99 lexus es300
1mz-fe engine
Can someone tell me which color goes with what valves?
Left one us brown
Right one is green
Thanks
Texas
Old Apr 28, 2019 | 01:30 PM
I'm guessing those are Fel-Pro if so green is probably intake. No instructions came with? I would verify with the manufacturer instead of guessing.
Old Apr 29, 2019 | 04:38 PM
whiskywine's Avatar
whiskywine
Default Colors
Repair manual says light brown is intake
And gray for exhaust
Confused. I would say green for intake as you said as well
I have green and brown
Darn
Old Apr 29, 2019 | 06:16 PM
Service manual is talking about OEM parts I don't know what those are. Usually the darker colour is exhaust. If it was me I'd buy OEM parts to be sure especially since I've had bad experiences with the so called Viton seals from Fel-Pro and other suppliers.
Old Apr 30, 2019 | 09:05 AM
whiskywine's Avatar
whiskywine
The car has 200,000 miles and a blown head gasket.
Even warpage was bad so discoloration was heavy and dark
With thick carbon .....even after cleaning the determining color was
Difficult .
My sequence of disassembly was accurate and labeled concisely, so after
Puting them under magnifying glass, I did notice that the intake stems have
And extra groove , so this helped me in determining my final calculation
The green turned out to be intake. You were correct
My conclusion to all this .......
Why would and OEM part be labeled Brown for intake?
I find this horribly inaccurate.
OEM lists brown for intake grey for exhaust
It's like making a yellow light purple ya know?
Thanks
Texas
Old Apr 30, 2019 | 03:07 PM
For OEM valve seals either grey or black has always been exhaust easy to remember because exhaust=carbon=grey or black.
NudleBoy
CT 200h Model (2011-2017)
May 15, 2019 11:39 AM
SOLID300
Jan 18, 2012 03:46 PM
xxpezzxx
Oct 4, 2007 01:06 AM
silkiechic
Dec 8, 2004 08:02 AM
SDSC300
Dec 3, 2003 01:55 PM
