master window switch vs window motors..HELP
Couldn't find this exact subject in current threads so help you can help..
Car is 2003 ES300. While replacing the window regulator (now works fine) had the master window switch replaced also, as the full up/full down had stopped working on the driver door and the driver side read window had quite functioning at all.
After replacing switch no difference. Have gone through reprogramming of all but no difference. The driver window switch is showing an intermittent but continuous blinking despite the "hold switch all the way up and continue to press until blinking light goes off" effort - won't quit blinking regardless. And rear passenger window will not roll up or down AT ALL, regardless of which switch is used (driver or passenger door).
What is the deal here? The driver window seems to be going very slow and is very glitchy. Could that be the window motor, and is that the same as the regulator? The read window is totally unresponsive. Could that be the same issue????
This is an old car, trying not to put more in it than have to. Help!!!
I'm hoping someone replies to this or you found a solution as I'm having the same issue except all the other windows work. Just the drivers window button shows a blinking light and none of the other posts or remedy's have helped. The drivers window will go up and down, it's just not with the auto function.
