Smart Entry Not Working.
Old Jun 18, 2018 | 09:50 AM
ESBabe's Avatar
ESBabe
Default Smart Entry Not Working.
Ok so a few minutes ago I pulled the ES in the driveway and (as I always do) I use the black button on the door handle to lock the doors but this time I noticed that the car made a beeeeeeeeeeeeppppppp noise until I opened and then reclosed the door, then it stopped. I opened all the doors including the truck to make sure everything was shut and nothing was in the way and then I tried to lock it again but it was a no go it did the same exact thing. So then I decided to lock the car with the key fob and that worked, so I tried to unlock it by grabbing the door handle and that doesn’t work either. So the smart key entry system isn’t working at all. So does anyone know what the problem could possibly be? Hopefully it’s not a super expensive fix or I may just leave it broken (if it is broken).
Old Jun 18, 2018 | 11:37 AM
nevernu's Avatar
nevernu
do you have the same prob when u try the second key fob? if not could be fob battery. Or is the second fob in the car maybe, that will cause all sorts of beeps/anomlys when u try to lock it
Old Jun 19, 2018 | 07:57 AM
ESBabe's Avatar
ESBabe
No the secondary fob is inside the house.
Old Jun 20, 2018 | 05:50 PM
heidihidin's Avatar
heidihidin
i have this issue intermittently with our 08
dealer put the fob right by the handle and it works then every time but what is the point?
new batteries did not solve my problem with 2 fobs just so you know
Old Jun 21, 2018 | 11:55 AM
ESBabe's Avatar
ESBabe
It actually corrected itself the next day. So it’s currently working and hopefully it will continue to work.
Scootymad
Feb 13, 2026 10:09 AM
pirate2050
Jan 12, 2014 09:42 AM
duke52
RX - 1st Gen (1999-2003)
Oct 3, 2013 10:16 AM
Shoegum
Sep 20, 2012 03:20 PM
dennis1a
Nov 11, 2006 09:45 AM
