Struts
Old Jun 11, 2018 | 12:48 PM
Mgrote's Avatar
Mgrote
Default Struts
Hello. I have a 2008 ES350. The ride was awful so I replaced the struts with KYB in the front and Monroe in the back. Did not change the springs. The ride is still very stiff and seem to getting bounced all other the place on a rough road still. The car has 180K miles on it. Is there any recommendations on what can be done to smooth out the ride? The tires are in good shape. They are Pirellis P7 All Season.
Old Jun 13, 2018 | 10:02 AM
BradTank's Avatar
BradTank
Sounds like you're in the wrong forum, but KYB struts are actually notorious for being stiffer than stock. Monroe has a reputation for being softer and stock Lexus are usually the best compromise for a luxury car ride.
Make sure your tires are inflated according to the door tag, something like 33 psi is what the factory recommends. Shops routinely like to fill them up to 40psi because most people are terrible about keeping air in their tires.
The biggest upgrade to a smoother ride is smaller diameter wheels because the tire is thicker. Makes a HUGE difference. So find the "smallest" factory wheels Lexus made and make sure those are on it. Even going down a single inch is pretty game changing. I think for 2008 Lexus even had 16" wheels as an option.
Old Jul 8, 2018 | 09:32 AM
Mgrote's Avatar
Mgrote
Brad. Thank you. Yes Discount tire did inflate the tire pressure to 40psi. Once i dropped to 30, as nited on the door it was a lot smoother. Thank you for the reply.
Old Jul 18, 2018 | 04:31 AM
norakat's Avatar
norakat
No offense but I think you're in the wrong forum. This is for 2013-2018 ES.
With my 2016 ES, believe it or not, a lower pressure did not necessarily feel better. Too low a pressure felt stiff and bad and so did air pressure that was too high. When I found the magic number, it felt much better and acceptable. For 17" rims this number was 43 pounds. For 18" rims it was something like 39 pounds. Even just one pound off from this number, lower or higher felt like a stiffer ride. and bumps were jarring. Having the right pressure or not is a dramatic difference even off by just one pound. Go figure..
Old Jul 18, 2018 | 04:44 AM
Mike728's Avatar
Mike728
Wow! That's way too high. Not only will the ride be like a rock, your tires will wear faster. I know, because my ES came out of the dealer at ~40psi. Did you switch to the 17's because the ride was too stiff on the 18's? I can't imagine running the 17's at 43psi is a good thing, either.
Old Jul 18, 2018 | 11:12 AM
norakat's Avatar
norakat
Mike: that’s what you would think, but no they feel the best and *softest!* and most comfortable at that pressure. My car originally came with the 18”, so yes I did switch to the OEM 17” to get more comfort. I drive professionally 8-12 hours a day.
justlmk330
12
Apr 13, 2019 05:59 PM
Stu
Feb 24, 2017 12:23 PM
acarapella
Jan 17, 2015 01:50 PM
DMPesso
Suspension and Brakes
Jan 20, 2011 05:58 AM
B-NIS
Mar 3, 2002 06:50 PM
