Help finding Paint code
Old May 17, 2018 | 02:03 PM
groat21's Avatar
groat21
I've just received touch-up paint, and am very disappointed in the colour match... it is much too gold, and I ended up removing the touch up paint... looks worse now, as I probably removed some old touch up paint that DID match.
Old May 18, 2018 | 01:01 PM
Oro's Avatar
Oro
Try an automotive paint shop. Any city with a decent number of body shops will have one.
I needed a spray can for some touch up on our 4ES under-door molding. My dad talked me into going to the specialty shop vs. ordering online from AutomotiveTouchUp.com or similar. This turned out to be good advice. They took the paint code and mixed me a can. Ours is that pale sea green metallic, I forget the actual name. It was about $20 or same as getting it online from the code as I recall.
It did not match well. They then took a hodded digital photographic device and “shot” an image of the paint to create a custom blend. The machine came back that it actually perfectly matched a Mitsubishi code, so they mixed me up a can based on that code, and it matched perfectly (it was the factory paint btw, never re-sprayed anywhere before). And at no charge since the first one didn’t match, though that was no fault of theirs and I did not ask for a discount/refund.
So check out that route - ask a body shop who mixes their paint if you can’t find the local shop yourself.
Old May 18, 2018 | 01:09 PM
groat21's Avatar
groat21
That is where I got the paint... Place called CarQuest. They have a no refund policy on custom mix paint though...
matt09
Jun 29, 2011 11:48 PM
exodus_2
Jan 16, 2008 01:48 PM
MDSC
IS - 1st Gen (2001-2005)
13
Jul 20, 2007 07:45 AM
KPC
Apr 25, 2007 11:48 AM
Benjamin T
RX - 1st Gen (1999-2003)
Jun 29, 2005 03:02 PM
