Multiple Codes!!
Old Apr 9, 2018 | 04:44 AM
RAFIQ609's Avatar
RAFIQ609
Default Multiple Codes!!
Has anyone ever seen this many codes at one rime??? Im reading here about camshaft sensors but would all these pending codes mean something more serious with the engine??...07 es350 UL...127000 miles
Old Apr 11, 2018 | 02:33 PM
RAFIQ609's Avatar
RAFIQ609
Default Update!
Just to update you guys...the problem was 3 bolts came loose from the vvt and messed up my timing chain ect....$3500 to send engine out to get it fixed...this was a recall problem with other models but not the Es yet it happened to me! Check engine lights came on...ran rough...then completely died and would start...couldnt depress brake pedal! Is it cheaper to put in a used engine? Should the Es been a part of that recall?
Old Apr 11, 2018 | 10:54 PM
Cjet's Avatar
Cjet
Aya Curumba......thanks for the heads up, had not heard of this before. Did you have any other indications prior to it letting go? Worse fuel mpg, rattles/unusual noises? Not sure on if a rebuilt would be cheaper. It might be. Wife's car (Corolla) blew a head gasket, and we replaced it with a rebuilt. That rebuilt seemed to have more power and better gas mileage than the original. Good luck either way.
Dkpgh
Feb 8, 2020 04:01 PM
cocora64
18
Feb 15, 2013 07:16 AM
Ashbypa
Sep 21, 2005 05:10 PM
Brucelex
Dec 2, 2004 05:53 AM
