Possible AC Problem
Old Apr 1, 2018 | 08:23 PM
Meatbucket's Avatar
Meatbucket
Default Possible AC Problem
So maybe I just don’t know what I’m doing but this is what is happening. . .
Both the driver and passenger temperature are set to LOW. The lowest they will go. The driver side is just blowing air. Not hot or cold. The passenger side is ice cold.
Am I doing something wrong or do I need to take it in?
Old Apr 1, 2018 | 09:39 PM
Meatbucket's Avatar
Meatbucket
If it helps I have a 2008 with the Nav System.
Old Apr 2, 2018 | 06:34 AM
jagtoes's Avatar
jagtoes
How cold is cold. Get a small AC thermometer and check the temps at each duct outlet. You need to see if the cold air is actually cold AC air meaning is the compressor working correctly. Also you might have a mixing valve problem where one side of the AC system is being blocked . You might want to consider having the AC system checked as you might be low on freon .
Hermyherm
GX - 1st Gen (2003-2009)
15
Aug 28, 2023 03:34 AM
mrvic
Aug 25, 2018 09:05 PM
actman
RX - 3rd Gen (2010-2015)
26
Jun 27, 2015 12:14 PM
parallon
Jul 12, 2014 02:47 AM
jami1
Mar 10, 2010 02:29 PM
