2015 Lexus ES300 foot light
foot light is on but very dim, before i use to open the door the light went on bright now it's very dim i checked all the fuses not sure what else i should check any ideas? thank you
Mike I see the light very dim use to be when i open the door it use to be very bright now it's very dim "when you say brightness turned up where do you adjust that option" upon changing to drive the light gets dimmer now it doesn't do that it might be the switch i am not sure
p.s
i am not talking about the dashboard light i am talking about foot light
p.s
p.s
p.s
good day Jollick I am referring the light on the ground not the door or else where, the lights works every where
the light LED on the ground doesn't get bright use to be brighter now i see the light is on but very dim
p.s
the light shines on the pedals
yes indeed Mike it calls footwell lights
p.s
Keep in mind that while driving they should be dim as an accent light. I just checked my 2013 and when I open the door, it is fades up and is kind of bright but eventually dims to a slight accent light. This is normal.
