sun visor light
the light that comes on when the sun visor mirror is open the light that's on the headliner is burn out do i just pull back the headliner from the windshield area or do i have to pull that down all together to replace the bulb ? and what bulbs are in there ?
or do i use a small flat head or dash trip kit to pry the plastic lens out of the headliner to replace the bulb ?
well after pulling it out and checking the bulb looked fine didn't look burn or popped
and it worked fine in another side
ended up playing around iwth the visor for like 10 minutes banging it and slamming it between both hands opening and closing it real fast finally it started working so apparently its a bad or was a bad switch in the visor itself.
