Burning oil
Old Jul 3, 2017 | 07:01 PM
jwalk0916's Avatar
jwalk0916
Default Burning oil
1997 ES 300 burning oil, but otherwise fine...told to just use 20w-50 and hope for the best
any solutions?
Old Jul 3, 2017 | 10:58 PM
Ace20Six's Avatar
Ace20Six
Have a compression test done, leak down test too while you are at it. Could be worn cylinders/piston rings. A compression test will be the one to tell you if there's a problem, leak down test will help pinpoint the problems location.
Could need some valve work or new valve stem seals, does the car smoke at all during start ups/while running?
Or you could simply have a oil leak somewhere
Old Jul 4, 2017 | 06:35 AM
PFB's Avatar
PFB
Could also be as simple as a blocked, or non functioning PCV valve.
easy to check and change if necessary.
Old Jul 4, 2017 | 09:30 AM
BDSL's Avatar
BDSL
any solutions?
Oil pump might not provide sufficient head to get the lubricants to all the engine parts at cold start and/or at operating temperature.
You have to find out where the oil is burning/leaking from.
Greg5OH
Jan 24, 2014 12:27 PM
lexsc400bl
Sep 21, 2011 05:37 PM
Jmai22
GS - 1st Gen (1993-1997)
Jun 4, 2010 01:12 AM
r4z0r3ck
Jul 19, 2002 08:58 AM
alvin
Apr 10, 2002 08:14 PM
