BIG PROBLEM WITH MY 92 ES: someone please help
Old Jun 9, 2003 | 04:50 PM
es30000's Avatar
es30000
Unhappy BIG PROBLEM WITH MY 92 ES: someone please help
Ok, ive had my 1992 ES for about 2 years now. Never had a problem till now. Here's whats up:
When I start my car, it acts like its gonna die. It revs up to about 1000rpm then drops to about 200rpm and keeps going back and forth. The car kinda shakes a little and the car will stall if I dont rev it. BUT, when I put the car in DRIVE, it stops. It idles at a normal 1200rpm or so and drives fine. But as soon as I put it back into PARK, it "pudders" like that. It doesnt just do this in the mornings or when i first start it. I does it all the time. Can anyone please tell me what might be causing this??
SHould I change the PCV valve? Throttle Bottle cleaner? Fuel Injenct. cleaner??
Someone please help, thanks!!!
Old Jun 9, 2003 | 05:34 PM
///MDex's Avatar
///MDex
Sounds like a vacuum hose may have slipped off. Just a guess.
Old Jun 9, 2003 | 05:59 PM
es30000's Avatar
es30000
where are the vacuum hoses located? ANything else causing this??
Old Jun 9, 2003 | 06:01 PM
EGainer's Avatar
EGainer
when my vacuum hose came off, there was no problems like this, and my engine light came on, so from my experience, i would not say thats what it is. but definitely have it checked....
Old Jun 9, 2003 | 06:20 PM
///MDex's Avatar
///MDex
Oh, OK - somebody with more experience. How many vacuum lines does this MY ES have and which lines did you have off when this symptom didn't exist?
Old Jun 9, 2003 | 06:29 PM
es30000's Avatar
es30000
so its not a possible loose hose?
Old Jun 9, 2003 | 06:41 PM
Nixsun79's Avatar
Nixsun79
I had this problem on the first car I ever purchased. Turned out to be the distributor, but I think the car would stall whenever I came to a stop, not just when the car was in park. Too long ago to remember.
Old Jun 9, 2003 | 07:00 PM
steviej's Avatar
steviej
I would have to go with idle air control motor is failing. It may also be the cam or crank shaft sensor.
Are you getting any "check engine" lights? If so, take it to someone that can hook up a scan tool and monitor for any trouble codes when they happen.
The other thing to look for is a tiny hole or crack in the hose that goes from the air box to the throttle body. This scenario is exactly what happens with you get a small hole or crack. Toyota/Lexus are prone to this problem. Simple replacement of the hose (if it is at fault) clears up any problems.
A flashlight place inside the hose and being in total darkness will illuminate any holes that may be present.
steviej
Old Jun 9, 2003 | 07:29 PM
EGainer's Avatar
EGainer
dex, i wasnt saying you were wrong, i was just saying that when my car had the vacuum hose come off, my car did not act that way. im not saying thats not what it is. anyway, id still have it checked out
Old Jun 9, 2003 | 07:43 PM
squarehat's Avatar
squarehat
Remember guys, the 92 had a different engine (3VZ-FE) than the 94+ (1MZ-FE). So the vacuum hoses may be a bit different. Also, the older engine most likely won't be OBDII scannable (anybody know if it's OBD I)?
Old Jun 9, 2003 | 08:05 PM
es30000's Avatar
es30000
I recently rigged up my own intake pipe and its probably not secured completely. Im just gonna put the stock intake hose back on there and it should clear the problem up...hopefully
Old Jun 9, 2003 | 08:07 PM
Nixsun79's Avatar
Nixsun79
Old Jun 9, 2003 | 08:16 PM
es30000's Avatar
es30000
ya think thats causing it?? maybe if someone would make an intake kit for the 92-96 ES, I would have to do such a dumb thing......
desertride
Dec 6, 2011 08:40 AM
lex1220
Jun 18, 2011 04:41 PM
ynvme
Oct 9, 2007 12:10 AM
Ice350
Mar 6, 2005 03:20 PM
