Timing belt Kit
Old Aug 16, 2016 | 12:17 PM
chrtorres's Avatar
chrtorres
Default Timing belt Kit
Hey - I'm looking to see what timing belt kits people are using on a 2000 es300. The car had it done at 97k, I bought the car at 122k and is now at 200k. Took it to my mechanic states it should cost about 750 to do it. Trying to save some money - would like opinions
Thank you
Old Aug 16, 2016 | 02:39 PM
808mcv20l's Avatar
808mcv20l
I've done the job on a 99 Camry V6, the difference is it is NON VVTI, however, the main parts are the same for 2000 ES.
This is the kit I've used.
http://www.ebay.com/itm/251117324213?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITI replaced everything including the thermostat.
I had to buy 2 bottles of AISIN coolant from my parts store (be sure to check if it's pre-diluted or not)
All parts from that kit are supposedly OEM from Toyota suppliers. There were no fitment issues on any of the parts.
Only thing I noticed was that the cam seals sunk in further than the original seals I pulled out (not sure if due to different manufacturer).
There's no leaks that I've noticed, the old seals were leaking quite a bit prior.
It was my first time doing the job and it did take me all day to finish, I also own a 2000 ES300 Platinum and plan to have it changed later, I anticipate it will go much smoother the second time around.
I watched the video by Speedkar9 along with some other guys videos on youtube.
I used the service manual for all torque specs.
Special tools needed were:
Impact gun (went out and bought a milwaukee 2763) couldn't have removed the crank bolt without it.
22mm impact 1/2" socket
Crank Holding tool
Crank Pulley Puller
Lisle seal puller (made removing cam/crank seals a snap) recommend this tool.
Cam gear Holding Tool
Cam seal installer (or piece of PVC pipe)
Torque wrenches (1/4" in lb for waterpump 3/8"ft lb for the rest, might need a big 1/2" one for crankbolt)
This timing belt job is very do-able for an experienced DIY, I wouldn't recommend to a novice though, worth the $750 to have someone else worry about it.
I may buy this kit for my ES300 as the seals and thermostat are from the dealer, but then again the last kit I used was good too.
http://www.ebay.com/itm/231995357641?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Aug 16, 2016 | 04:01 PM
speedkar9's Avatar
speedkar9
Get the Aisin kit from RockAuto. It includes the idler, tensioner, tensioner bearing, timing belt and water-pump. If your cam and crank seals are leaking its a good time to change those too. You might also want to change the alternator and power steering belts, and the dog-bone engine mounts if they're cracked, since those have to come off anyway when doing the job.
Just to give you an idea, the parts should be roughly $250. Labor should be ~6 hours, so multiply that by an average labor rate of $70-100/ hour and the $750 quoted to you sounds reasonable.
Here's my video on the 1MZ-FE timing belt:
And here's a thread with the highlights of the job:
https://www.clublexus.com/forums/es-...ml#post8604029
Old Aug 16, 2016 | 10:05 PM
80es300's Avatar
80es300
The cam and crank seals on this car are known to leak, so replace them along with the timing belt. I suggest you get Toyota OEM cam and crank seals. Like speedkar said, Aisin kit is good for the other parts
MickyT
GX - 1st Gen (2003-2009)
Feb 15, 2016 07:27 AM
gebo
Maintenance
May 14, 2015 07:22 PM
mjatondo
Mar 27, 2014 06:13 AM
islexusred
Feb 19, 2014 09:21 PM
k311in
Feb 24, 2011 06:29 PM
