Fast left blinker
Revolve? I've tried them and they look nice. Don't have them anymore, just the rear brake and turn signal. And it blinks twice as fast. Don't now why, no bulbs out, no fuses out.
Plan to turn all of them to LED soon and something else to resolve my reverse light issue.
sometimes the bulb isnt put on properly and you dont notice... that makes the bulb blink fast too.
Well, one thing to check it the connector that goes to the headlight assembly for the turn signal/parking lights....if the bulb is flashing faster and both the front and rear are working, the problem is with the ground ckt. in the bulb socket or the connector... if you look close you will see that there is a significant dirrerence in the intensity of the turn signal that is fast and the normal one.... what is happening is rather than lighing the high wattage element of the 1157, because of the faulty ground it is going through the low wattage element, (low wattage = higher resistance = faster blink....) I=ER
I current, E voltage, R resistance... ohms law...anyway, the turn signal/parking lights cann be accessed from under the car, remove the plastic unbody cover on the side where the bulb is, look up you will see the grey thing refeerred to above....but!!!! the easier thing is remove the three 10mm bolts holding the headlight assembly in, unplug the high and low beam connectors and pull the headlight assembly away from the body... piece of cake.... hope this helps...
capn
capn
I started to have this problem too. The Lexus dealer said it was a loose connection because if both the front and back blinkers still flash, the bulbs are still good. He said to turn on the blinker that is flashing too fast, go to the front flasher, hit it with the palm of your hand until the blinking slows down.
Strange, but it worked for me.
Maybe I read wrong but this is about some sort of grounding issue with bulb holder do I understand this correct? I own an 1996 ES300. When I have time I will try the suggestions here..thanks guys
Sorry oolldd thread but I had the basic same issue with my front right blinker going twice as fast...yesterday the easy fix was done first remove headlight assembly of the side your problem exist...remove bulb/socket from assembly by twisting off then check bulb and holder contacts if not corroded as in my case...then reinsert and twist in but just to lock position DO NOT OVER-TIGHTEN!!! Before remounting headlight assembly check how blinkers work if it back to normal then your situation was the bulb and socket were over tightened..thus the connection was not correct but testing while headlight assembly off over tightening it blinked fast but once tightened to when it feels fine it works then go ahead and reinstall headlight assembly.
awesome, i just went out and did it...works for me too
