Turn Signal two different speeds?
Old Jan 17, 2016 | 05:13 PM
KSES300's Avatar
KSES300
Default Turn Signal two different speeds?
I picked up a right side taillight from a local salvage yard and everything's a good match, but turn signal speed. In my original turn signal on the left side, the flash speed is about twice the speed of the one I got for the right side. It came out of the same year car and model car, so what gives? Can I adjust this somewhere? Is it the bulb? I would appreciate any help with this matter.
Old Jan 17, 2016 | 05:20 PM
PFB's Avatar
PFB
Assuming the wiring and bulb contacts are good, than It's the bulb. Make sure that you get the specified bulb, and that both front bulbs are identical.
Old Jan 17, 2016 | 07:07 PM
Corkman's Avatar
Corkman
If you don't have any extra bulbs, switch sides and see if the speed different follows.
Old Jan 17, 2016 | 08:43 PM
Chocolate's Avatar
Chocolate
You will get hyperflash if a bulb is out or drawing less than 25w.
Old Jan 18, 2016 | 05:09 AM
KSES300's Avatar
KSES300
Oh, so the failing bulb is the rapid flashing one? Good to know. That will save me some time. Thanks for all of the replies!
Old Jan 18, 2016 | 02:03 PM
Chocolate's Avatar
Chocolate
Yeah, the front or rear bulb of either side being out/drawing low current will cause that entire side to hyperflash.
Old Jan 18, 2016 | 03:33 PM
KSES300's Avatar
KSES300
So, all of the bulbs are lit, so I'll just have to test them one at a time....but not today in 19 degree weather.
Red Green
GX - 1st Gen (2003-2009)
Sep 12, 2010 12:05 PM
tmf2004
22
Jul 20, 2008 04:49 PM
tuan92129
Lighting
Aug 28, 2006 09:50 PM
BILLIARDS
Feb 24, 2006 09:08 AM
fierce gs
Nov 6, 2001 07:40 PM
