a/c noises even when a/c off
Old Apr 27, 2015 | 08:16 AM
sugarspotz's Avatar
sugarspotz
Default 02-300 a/c noises even when a/c off
2002 es300
I was told a few years ago I had a vent control module going bad.
ac makes a loud bubbly grumbly noise and now an electrical "read" noise. the electrical noise is coming from foot well. sounds like the kick plate but definitely the foot well. the ac noises are in front of the driver.
I have found vent modules and there are 4 of them. im being told the "actuators" is failing that's why im hearing the electrical signal being sent repeated times. would an actuator be a vent module. the ac & heater modules are behind the ac panel in the dash
Old Apr 27, 2015 | 09:23 AM
gtstcactus's Avatar
gtstcactus
what year is your car? have you run a/c diagnostics?
Old Apr 27, 2015 | 09:35 AM
sugarspotz's Avatar
sugarspotz
No codes in cpu yet. I have a friend with a scannerS that I will have test it then. Im having some other things that he cant test too while we are at it.
Old Apr 27, 2015 | 01:15 PM
PFB's Avatar
PFB
I assume you are referring to your 2002 ES300. If so, there is a sequence of buttons that you can press on the climate control unit that will display stored AC trouble codes (if any) on the climate control's screen. No OBD II code reader required.
Unfortunately I don't remember the sequence, but if you do a google search, or search this site, you may find it.
Otherwise, hopefully someone that does know will chime in.
BTW, You should always include the year and model of your car in your post. (I had to look it up on your profile)
Phil
Old Apr 28, 2015 | 05:35 AM
sugarspotz's Avatar
sugarspotz
Sorry I though it was on my moniker but it doesn't show on this site. 02 es300
Old Apr 28, 2015 | 05:48 AM
sugarspotz's Avatar
sugarspotz
found this
"Running the A/C system diagnostics: Press RECIRCULATION and AUTO buttons together and turn key to ON position and watch the LCD aircond. system screen normally used for temperature settings for a numerical code indicating the problem area. BTW, zero zero (00) means normal. First, all indicator lights will flash 4 times, then a buzzer beeps. When error codes are displayed a short while later, slower display can be activated by pushing RECYCLE."
once in test mode you can start the car to test temps etc
Push front defrost button and it will put you into actuator mode? it moves through the vents positions individually. Once in this mode press recycle to stay in a certain position for testing.
to clear ac codes press front and rear defrost together
told to test on sunny day or it can throw solar senor codes falsely.
Old Apr 28, 2015 | 06:38 PM
gtstcactus's Avatar
gtstcactus
found this
"Running the A/C system diagnostics: When switching ignition ON push RECIRCULATION and AUTO buttons together and watch the LCD aircond. system screen normally used for temperature settings for a numerical code indicating the problem area. BTW, zero zero (00) means normal. First, all indicator lights will flash 4 times, then a buzzer beeps. When error codes are displayed a short while later, slower display (step mode by repeatedly pushing Fresh) can be activated by pushing FRESH. Hitting OFF stops the diagnostics."
Yeah that's the procedure on my 1992... So if it works it should check all the sensors and then run through all the actuators (or whatever controls the routing of airflow to your selected destination) to test they are ok...
I can't recall off the top of my head which button but once activated there is another button press to switch between the sensor and actuator check (I think)...
Old Apr 29, 2015 | 06:03 AM
sugarspotz's Avatar
sugarspotz
codes 21 and 24 solar circuit both sides. Not sure what that means yet. This is what is stored I will clear and manually test in full sun.
Old Apr 29, 2015 | 06:05 AM
Mphidd's Avatar
Mphidd
found this
"Running the A/C system diagnostics: When switching ignition ON push RECIRCULATION and AUTO buttons together and watch the LCD aircond. system screen normally used for temperature settings for a numerical code indicating the problem area. BTW, zero zero (00) means normal. First, all indicator lights will flash 4 times, then a buzzer beeps. When error codes are displayed a short while later, slower display can be activated by pushing DEF (step thru modes by pushing DEF for each senor position). Hitting OFF stops the diagnostics."
I'm going to try this on my 1999 ES300
Lobeaux
Aug 31, 2015 06:08 AM
urbanriz
Sep 17, 2014 06:06 AM
esucaris1
Aug 17, 2009 07:10 PM
Toshima
Aug 11, 2007 05:02 PM
red02is
IS - 1st Gen (2001-2005)
Aug 4, 2007 01:24 PM
