abs ,vsc light is on
Old Apr 15, 2015 | 12:40 AM
alohaman's Avatar
alohaman
Default abs ,vsc light is on
Hi guys.. I just recently change the rear struts of my 00 ES 300 now my ABS and VSC light is on can somebody tell me on what seems to be the problem? please help thanks in advance guys..
Old Apr 15, 2015 | 11:20 AM
alohaman's Avatar
alohaman
oh its the abs indicator is on and the trac off indicator is blinking.
pls. help thanks.
Old Apr 15, 2015 | 11:52 AM
PFB's Avatar
PFB
You probably tore or disconnected one of the abs sensor wires while doing the work In the back.
Double check your wires and plugs. Use a VOM meter. I'm sure the problem is there.
Phil
Old Apr 15, 2015 | 04:38 PM
alohaman's Avatar
alohaman
Thanks I will that..
alohaman's Avatar
alohaman
Thanks I will try that first ..
Old Apr 16, 2015 | 08:52 AM
alohaman's Avatar
alohaman
Any suggestions or sites where to buy a decent speed sensor but not too pricey..?thanks
Old Apr 16, 2015 | 09:12 AM
Search these part numbers on Ebay or try Rockauto.com
89546-33020
89545-33020
Old Apr 16, 2015 | 09:45 AM
alohaman's Avatar
alohaman
thanks I will try that
Old Apr 16, 2015 | 01:38 PM
PFB's Avatar
PFB
If you confirmed that your problem is an ABS sensor and not a torn wire as I suggested, than you can try cleaning them first.
Sometimes Break dust or other contaminants get in there and prevent them from working properly.
Since however it happened right after you changed your rear struts, I still bet on a torn ABS wire or a disconnected plug.
Phil
Old Apr 16, 2015 | 09:04 PM
alohaman's Avatar
alohaman
I checked the continuity by volt meter the rear left doesn't have the continuity at all. the other side have..
Old Apr 19, 2015 | 01:10 AM
alohaman's Avatar
alohaman
Thank you guys for all the advice works good now..
Old Apr 19, 2015 | 06:00 PM
PFB's Avatar
PFB
So where was the problem, and how did you fix it?
Old Apr 20, 2015 | 01:06 AM
alohaman's Avatar
alohaman
you are absolutely right.. I changed the rear left abs/speed sensor I asked the dealer, quoted me $282 what..? So I went to the junkyard I found a 2000 toyota Camry, removed the parts and check the continuity with my volt meter ,I checked the parts no. (good thing identical to my old part no.)then replaced it..then drive around the block ,then suddenly stop the blinking, gone the indications lights..I so happythanks again man..
Luciefer
Suspension and Brakes
Jun 27, 2016 01:39 PM
Jayd41
May 21, 2014 09:26 PM
peewhy
Apr 12, 2010 02:28 AM
systemover
Oct 31, 2008 02:22 PM
AKY
Feb 22, 2007 02:58 AM
