Normal Shift Points 1999 ES300 ???
Old Feb 20, 2015 | 10:21 PM
Ultramiler's Avatar
Ultramiler
Default Normal Shift Points 1999 ES300 ???
My ES300 seems to drag out the gears, it will sometimes cruise at 2,500-3,500 RPM. I am just wondering what everyone else's shift points are, at what RPM/Speed do you shift into what gear? Just to be clear I am talking about automatic transmission.
Old Feb 20, 2015 | 11:50 PM
ES300NZ's Avatar
ES300NZ
Mine does that when the overdrive isn't on, but yep, I've seen 2,500rpm cruises, not 3,500rpm though, that's quite high.
Old Feb 21, 2015 | 03:44 PM
lostape45's Avatar
lostape45
I'm a very observant person so I'll share my notices.
Under normal acceleration
1-2: 2500
2-3: 2750
3-4: 3250
Under harder acceleration
1-2: 3250
2-3: 3500
3-4: 3500
Just how I drive. At 70mph on the highway I cruise at about 2750rpms, around 65mph at about 2500.
Old Feb 22, 2015 | 03:25 PM
jltait's Avatar
jltait
Make sure your overdrive is on and that you're transmission fluid is not low.
Old Feb 22, 2015 | 06:11 PM
Ultramiler's Avatar
Ultramiler
Thanks for the replies, I will have to take note what all my shift points are next time I drive. I just noticed that it seemed a little high, but I just got the car so I might not be used to it. I think I was going about 40mph and it was at like 2800rpm and not shifting even when I let off the gas slightly. It does shift, and it isn't exhibiting slipping or hard shifting so I think it is ok.
Old Feb 23, 2015 | 05:08 AM
lostape45's Avatar
lostape45
2800 at 40mph is not normal. Is this all the time or just when you first start it? When it's cold the transmission doesn't shift into 4th/overdrive until it's warmed up. I haven't taken note of any exact rpms at 40mph but they should be under 2000.
Old Mar 6, 2015 | 10:21 AM
Ultramiler's Avatar
Ultramiler
This seems to only happen when it is cold. When I say cold I mean left outside overnight in negative temps.
I think the 3,500 May have just been s fluke, but 2,800 happens whenever it's real cold
Old Mar 6, 2015 | 10:30 AM
lostape45's Avatar
lostape45
Until the transmission warms up, it won't shift to 4th gear to protect itself. The engine is revved high so the transmission heats up quicker too. It's only noticeable like you said, when it's extremely cold outside.
acarapella
24
Nov 5, 2018 08:46 AM
Iedwards23
Nov 27, 2017 09:07 PM
CwVwH
Feb 4, 2013 02:50 PM
andybisnut
Dec 28, 2012 12:28 AM
Wert
Jun 24, 2008 09:46 AM
