Don't tilt down in reverse
Hello, I have a 2003 es 300. It's pretty well loaded… Has auto leveling headlights, although I don't understand what they're supposed to do. They seem to always be aimed to close in front of the car. Anyway,
I thought that 2002 to 2006 ES 300s and ES 330s had Sideview mirrors tilt down when in reverse? Mine doesn't do that. Is it a setting that I could turn on?
That's a bummer. It's also what I thought, too, but one source, is unreliable as it may be, indicated that all mvc30 02-06 ES models did it. I would love to have that! But I guess for now, I'll just keep slamming into stuff in reverse
I manually tilt them down when parallel parking, which is my main reason for wanting that feature.
I wish there was a way to hack and reprogram the computers in our cars. I mean a way that the intermediate skill level can achieve. I am sure some super computer scientist could. I have only written in basic, pascal and c++ on a windows pc
I tried the switch in the L or R position. Didn't work
I like the 05/6 better for some of thier features. This being one. Also wheel audio control, projector lights, and the more elegant tail lights. I prefer the 3mz as well. Gets 3-4 mpg better. I am not crazy about the lighter wood and bigger wheels.
Perhaps my next car will be a later 330. Or a 300h.
So what's the point of the auto leveling headlights in my car? They seem to only move when I start the vehicle. And they are always aimed to close in front of the car
The only problem with that is, the car needs to be in Park for the memory seat function to work. Memory seats, by the way, are absolutely awesome. This is the first car I've ever had that has them. For whatever reason, my 2008 Is250 premium, nor my 2012 infinity G 25 Journey had them
I will tell you this: for two dollars you can get those little convex mirrors for the upper or lower outside corner of the side views, and see so, so much more. I just don't like that they don't damn with the rest of the mere
I found a explanation in the 2003 Manual, hope this helps:
Yeah I read about using the memory function for reverse tilt in the Toyota Tundra forum.
True. When you roll up to a parking spot, you'd have to shift first to P, then hit #2 for the mirrors to tilt, then drop back into R.
If you look at the wiring diagram for the seat control unit, it needs an input from the transmission or braking system of the car, telling it that its in park. If you could supply 12V to that pin, you could trick the memory seats/mirrors into working while you are in any gear. According to the diagram for the 3ES, it would work, but I'm not sure how its setup on the 4ES.
For me, the little convex mirrors are way too small to see anything. My car came with it and the first thing I did was rip them right off.
Thanks guys ! Great info.
The headlights that go around corners like in the 08 is250 I had were super obvious. They were awesome. I'll adjust my headlights tomorrow. Thanks!
I may mess with the wiring for the memory. I am going to start looking into to changing firmware and software too. It can be done. I'd love to learn how to reprogram things like write my own transmission code or something
I wish I could get into reprogramming too. Then I can reprogram the throttle to NOT have built in lag.
Yea I imagine they would be but someone's had to have done it.
Do an eBay search for the throttle thing. When I first got my 2010 Camry, the lag drove me nuts. Turns out they make a module that plugs in and adjusts it. I never bought it because I didn't want to spend the moneys, but it can be done!
There's a thread about people doing it to their 5th and 6th gen Camry's on TN, so I assume it could be done to our 4ES as well:
http://www.toyotanation.com/forum/10...yes-no-42.html
Theoretically it changes the response curve of the throttle potentiometers so that its sharper. That's the equivalent of pressing the gas pedal harder, but not necessarily eliminating the lag, more of removing the dead spot at the beginning of the pedal travel.
